Removing Powder Coat? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Paint and Body > Removing Powder Coat?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRubicon Express Suspensions from CCOR 706-207-4140Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955
Unread 08-04-2014, 03:23 PM   #1
Robbie13
Junior Member
Robbie13's Avatar
Ok, I bought some Olympic rock sliders for my wifes Jeep. It's a Sahara. I ordered the wrong ones since I have that plastic piece between the front/rear fenders that is anchored by a piece of metal that is riveted to the body under the doors. Ones I bought are too narrow. No prob. I will weld some 1 1/2" flat bar to the top to make the difference up. My question is the sliders seem to be powder coated and naturally when I weld the new flatbar in place this will ruin that. Can it be sandblasted off and redone? What type of abrasive to use?
2000 Jeep Sahara 4.0 3Spd Auto 3.5" Zone Lift 33" Duratracs 4.10 ECGS Axles
Robbie13 is offline   Reply With Quote
Unread 08-04-2014, 06:30 PM   #2
Jim1611
Jim1611's Avatar
The powder coat won't come off very easy if it's very thick. I've found that it softens up if you use some heat on it, like a small propane torch. Scrape what's lose away then sandblast the rest. Worked great for me.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote
Unread 08-05-2014, 02:49 PM   #3
Robbie13
Junior Member
Robbie13's Avatar
Will try that. Thank you!
Unread 08-06-2014, 02:44 AM   #4
TexasJeep01
Auto one has aircraft removing paint spray, this stuff is pretty powerful it seems and takes off anything to the bare metal.
TexasJeep01 is offline   Reply With Quote
Unread 08-06-2014, 02:45 AM   #5
TexasJeep01
That or you could soak an rag in some mineral spirits or paint thinner and set it on the powder coat for a few hours. Hope it helped!
Unread 08-06-2014, 08:22 PM   #6
Jim1611
Jim1611's Avatar
You're welcome. I have also tried aircraft stripper and it was marginal.
My build thread
Unread 08-07-2014, 07:42 AM   #7
swirve
If its good powder then the only way to get it off is sand/ grind or have it blasted. Stripper wont touch powder coat
swirve is offline   Reply With Quote
Unread 08-25-2014, 02:38 PM   #8
y2k-fxst
1964 CJ6
When I worked in the factory and we had parts that came out bad from the powder paint line we had to put them in the burn-off oven we used for the racks then scotch brite clean and recoat.
Just picking brains, mines worn out!
y2k-fxst is offline   Reply With Quote
Unread 08-26-2014, 01:02 PM   #9
Mambo_Dave
This is good inside knowledge, thank you.
What temperature was that burn-off oven?
Mambo_Dave is offline   Reply With Quote
Unread 09-01-2014, 10:10 AM   #10
y2k-fxst
1964 CJ6
Unfortunately I am not sure, we burned off the racks every-other day as powder coating would build up to the point it didn't get good ground. I would guess around 7-800 degrees as it was black heat when racks were removed, not hot enough to cherry the parts. But, would be high enough to draw temper on hardened parts such as springs. Start drawing temper at around 600 degrees.
Unread 09-15-2014, 03:25 PM   #11
Robbie13
Junior Member
Robbie13's Avatar
Man this stuff is hard to get off. I used Rust-Oleum Aircraft Remover. This got the biggest majority of it off. The nooks and crannies that were left I tried to use my buddy's small sandblaster. Wouldn't touch it. I read that using Permatex gasket remover may work, so I will try that next. Also, the aircraft remover puts light surface rust on quick! Understandable since I am sure it is eating into the metal as well. When I get this stuff off I plan on getting them Rhino Lined.
Unread 09-15-2014, 03:46 PM   #12
swirve
Its the air that puts the rust on and most likely the water that you are using to neutralize the stripper
Unread 09-15-2014, 10:29 PM   #13
athos76
That's flash rust and is a by-product of using an acid on steel. The moisture in the area can attack the steel in minutes
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline   Reply With Quote
Unread 09-16-2014, 03:53 AM   #14
Copperhead89
I would burn off whats left with a propane torch.
My YJ/CJ Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline   Reply With Quote
Unread 09-16-2014, 02:53 PM   #15
Robbie13
Junior Member
Robbie13's Avatar
Yep. Going to try that as well. Going to have to blast it to remove the surface rust left behind too. Was expecting that anyway.
