Removing Herculiner - JeepForum.com
post #1 of 16 Old 12-02-2009, 06:59 AM Thread Starter
GroundAssault
GroundAssault's Avatar
Removing Herculiner
Does anyone know how to do this? I put it in last year and now want to U-Pol Raptor the inside. How do I remove the herc? Did a search and it was all on how to put it in or which liner is better. TIA
2006 Jeep Wrangler---SOLD!
Nowhere at present is there such a measureless loathing of their country by educated people as in America. --Eric Hoffer
Originally Posted by rmb2485
cheap mods are like a drug dealer giving you your first few for free...they will only get you addicted and before you know it every paycheck goes into your new habit :rofl:
GroundAssault is offline
post #2 of 16 Old 12-02-2009, 07:09 AM
bhamilton5006
whats wrong w/ the herc? I just bought some the other day!!
I would try scrapping it out and using acetone. the acetone will break up the adhesive in the herc!
bhamilton5006 is offline
post #3 of 16 Old 12-02-2009, 03:17 PM
hulud44
Fish Monger
hulud44's Avatar
really ure better off just keeping the herc. if it didnt come out ok then just keep applying it till its thick. and ur really gonna have to break ure *** to get it off. but id say a really tough wire wheel is ure best bet.
hulud44 is offline
post #4 of 16 Old 12-02-2009, 03:18 PM
99TJSahara
try heat........
-Joey
04 Grand Cherokee Overland
-sold
99TJSahara is offline
post #5 of 16 Old 12-02-2009, 03:21 PM
MarineJRM
Xylene is what they call for to thin it in the instructions. I would think that you could easily put the raptor over the herculiner.
"Do what you think looks better, its your Jeep. Word of advice, they are a pain to keep white, I have to clean em every few months"
MarineJRM is offline
post #6 of 16 Old 12-03-2009, 02:50 AM
karlo
Here are the steps on how to remove Herculiner:
How to Remove Herculiner | eHow.com
karlo is offline
post #7 of 16 Old 12-03-2009, 08:14 PM Thread Starter
GroundAssault
Thanks karlo.......Actually guys, the herc came out great. I just don't like how rough it is. I have been seeing the raptor and the smoother liners and thought that would be more my bag. I don't know if I am going to actually remove it now.
Aircraft stripper has to be one of the nastiest chemicals known to man.
post #8 of 16 Old 12-04-2009, 02:16 PM
cidd
If you do this be carefull aircraft striper is nasty stuff if you get on you it burns like h@ll and the fumes are bad also so do it in the open air. If this stuff touches the paint on your jeep the paint will be gone it will also melt the sole of your shoes and burn holes in your clothing. But it does work
cidd is offline
post #9 of 16 Old 12-05-2009, 07:53 AM
89YJmoneypit
KMG365
89YJmoneypit's Avatar
I found out welding close to it does a pretty good job of removing it too
89 YJ
Transplanted '99 4.0, AX-15, NP231
Red Jeep club #8
Now belongs to my daughter.
97 ZJ Laredo
4.0, 42re, NP242
R.I.P.
Marseilles Fire Dept:
89YJmoneypit is offline
post #10 of 16 Old 12-16-2009, 12:10 PM
aircruiser
aircruiser's Avatar
im just subscribing to this so i can find it later...thanks karlo!
aircruiser is offline
post #11 of 16 Old 12-16-2009, 03:15 PM
Motorcharge
According to the Herculiner site, you can't
Q: How can I remove HERCULINER once it's applied?
A: You can use Xylene while product is still wet, but if it dries,
it's permanent.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #12 of 16 Old 12-26-2009, 12:44 AM
vilseck21
I used Xyl to get if off a garage floor, just pour it and let it sit, use about a quart per 5 square feet, then get a paint scraper, peel it off, then sand the rest down. Make sure you do it out side, and have a ventlator
vilseck21 is offline
post #13 of 16 Old 02-02-2010, 07:32 PM
USMCEOD
Good advice on the aircraft stripper. I have a third coat drying in my tub right now, and two of my seat bolt holes have herc in them. I had tape in them and over them, not sure how it happened....
I might drip some aircraft stripper down them before I tap and die the holes. Then again, I love my work boots, and I don't want to burn holes in them!
USMCEOD is offline
post #14 of 16 Old 05-21-2010, 05:51 PM
AggieTreed
I know it says on the herculiner instructions not to use anything other than xylene or acetone with the paint. I imagine some paint stripper should do the trick, and its more readily available than aircraft stripper I'd imagine.
"Marx says that capitalism is the exploitation of man by man. Well I say communism is the exploitation of man by government."
Thanks and Gig 'em!
AggieTreed is offline
post #15 of 16 Old 05-23-2010, 09:47 AM
Ironworker709
Ironworker709's Avatar
Buddy of mine recently used the herculiner in his truck bed,2 months later it was all scratched up,it didn't hold up well at all to sliding things in and out of the bed .
We used the Aircraft Stripper carefully,put it on with a brush in a cool dry area under a tree,then put saran wrap over it and let sit for about a 1/2 hour then peeled it up with a putty knife,re-applied the stripper where needed.
The saran wrap keeps it from drying out so quick and works longer,it dries up pretty quick on a hot day and won't penetrate much.
You have to be real carefull not to get the stripper anywhere you don't want paint stripped,that's why we used paint brushes and carefully put it on then let sit for a long time to do it's work and removed the saran wrap and let sit for a few minutes more so it dryed up a bit and wouldn't slop around when scraping with a putty knife.
Aircraft Stripper is nuetrulised with water,just wash it down with soapy water afterwards and then sand and prime to keep the bare metal from flash rusting.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
Herculiner application inside a TJ RedJeep2002 Paint and Body 19 10-18-2010 08:19 PM
Herculiner Exterior teufelhundren Paint and Body 1 02-02-2010 09:06 PM
Making Herculiner "Floor Mats'??? jesseleikerjeep Paint and Body 2 01-25-2010 03:34 PM
Where to get Herculiner? PrJeep Paint and Body 10 01-02-2010 12:28 PM
another herculiner 88YJoe Paint and Body 3 10-27-2009 11:09 PM
