Rear seat bolt holes - JeepForum.com
post #1 of 6 Old 10-16-2013, 01:42 AM Thread Starter
ChrisTJ34
Im about to herculine the interior of my jeep and i want to close up the rear seat bolt holes since it didnt come with one and i dont see me getting one. I dont know much about welding and i want to do the herculiner application myself. What would be the best way to go about closing the holes?
ChrisTJ34 is offline
post #2 of 6 Old 10-16-2013, 07:16 AM
rjbruzan
I would tape the holes on the bottom or outside and then fill with bedliner. Welding would cause rust problems later down the road. And the next owner could install a rear seat by cleaning out the holes if needed. Dont add more work thats not needed.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 6 Old 10-16-2013, 07:36 AM
ToledoDave
Chris.... just get bolts for the holes and spray over them. Later down the road if you need the holes back just remove the bolts. They are 12mm x 1.75
ToledoDave is offline
post #4 of 6 Old 10-26-2013, 06:01 AM
responder
yup, x2
responder is offline
post #5 of 6 Old 10-26-2013, 08:31 AM
Ironworker709
Ironworker709's Avatar
This^^^....
And if you want the bolts to "disappear"?...
Buy some allen head type headless bolts the same thread and size as yours commonly used as plugs
They are bisicaly a bolt that is just all threads with no head on it,and an allen wrench type hole in it for the wrench...use some blue loctite on the threads and screw in untill flush..bedilner over them.
This way you have the options down the road to reuse the holes if you or another owner wants by picking the bedliner off the bolts and remove them
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #6 of 6 Old 11-03-2013, 05:28 AM
silvanus
Or use foam earplug protector's, twist then push them flush into the nut when they expand they fill the cavity nicely!
they pop out when ready for use, or leave it, I used this set up when I applied my POR 15 bed liner last year, nice little trick!!
silvanus is offline
