Raptor Lined my Hard Top - JeepForum.com
post #1 of 5 Old 07-09-2011, 03:23 PM Thread Starter
usanoe
Made two attempts at painting my hardtop with black paint rattle cans with unacceptable results so I decided to use Raptor Liner on it. Must have had wax and/or grease still on the top. Because of this, I did an additional step and cleaned it thoroughly, then sprayed a self etching primer on the top of my hardtop. I did not do this on the sides, back or two front pieces of the freedom top. I do not notice any difference between these areas now that I am finished.
I ordered the kit (U-Pol Product 0820V) off of eBay. This kit came with the spray gun. I did see some kits that didnt, so make sure you get one.
Other items I used:
Paint Thinner - to clean the gun between coats and once youre done.
Scotchbrite General Purpose Pad - to scuff hardtop prior to painting
Acetone - to clean off overspray from any unwanted areas
Rubber gloves
Painters tape
One of the most important things you need to do is tape off any areas you do not want overspray to get onto. Taping can be a pain but well worth it as cleaning off the overspray was much harder.
The instructions say to use between 40-70 psi so I set mine at 60 psi.
Shoot the sides first so you are not tipping the bottle sideways allowing the liner to leak out of the top vent hole in the gun.
Also, keep the gun pointed directly at the surface being painted rather than an angle or the material in the liner will skip across the surface making it look like small worms.
Here is after the first coat.
Instructions say to let it dry at least 60 minutes between coats. here is immediately after the second and final coat.
I used 1 2/3 bottles on all three pieces of the top. It appears to have come out really nice. Once it completely dries and I get it installed, Ill take some more pictures.
Since i had some left over, i also shot an extra rim I had in the garage.
Current: 2008 Silver Unlimited Rubicon, 4dr, Auto, Rough Country 2.5" lift, Custom Made front bumper, Scrockworks Rear Bumper
Prior: 2008 Flame Red (Recon) 2dr X, 6 Spd, Trailmaster 5.5" lift with 1" BL, 37" BFG Kevlars on 17" XD Addicts
usanoe is offline
post #2 of 5 Old 03-12-2012, 05:34 PM
CaptAmerica219
How has it held up?
CaptAmerica219 is offline
post #3 of 5 Old 03-15-2012, 02:54 AM
karlo
It turned out really nice. By the way, any prep you did for the rim?
karlo is offline
post #4 of 5 Old 03-17-2012, 10:15 PM
kashoggio
Should of taken the weight off the wheel first... Other than tha, looks cool
2004 TJ RUBICON~ LIME GREEN
"Some desire is necessary to keep life in motion."
kashoggio is offline
post #5 of 5 Old 03-13-2013, 04:54 PM
Jeepnaut
Originally Posted by CaptAmerica219 View Post
How has it held up?
I want to know, too.
Jeepnaut is offline
Lined my tub with Duplicolor bedliner sam24th Paint and Body 16 08-22-2011 06:16 PM
U-pol Raptor underneath the Tub??? GilNewJeeper Paint and Body 5 06-18-2011 02:49 PM
Raptor Liner DIY Raabicon Paint and Body 3 05-31-2011 09:58 AM
Upol Raptor, CFM, and PSI Austinb86 Paint and Body 4 05-18-2011 09:39 PM
using raptor to paint my car fastfocus Paint and Body 6 03-06-2010 09:47 PM
