Question RE: Loctite & Body Mounts - JeepForum.com
post #1 of 7 Old 07-23-2013, 10:09 AM Thread Starter
simspace
I am installing a body lift kit and I am curious if I should use red or blue loctite on the body mount bolts.
Based on what I read in the loctite tech specs, red seems like overkill to me. But it is my sons Jeep and I want him to be safe, especially when he goes off-road.
I'd appreciate your opinions!
Chris
simspace is offline
post #2 of 7 Old 07-23-2013, 11:53 AM
nolanbalzarini
im not 100% sure on this, but i think that a bolt with red lock tight can be removed if you heat it up.
so use the red and it wont come off unless you want it to
nolanbalzarini is offline
post #3 of 7 Old 07-23-2013, 01:11 PM Thread Starter
simspace
Thanks for your response nolanbalzarini. You're right, high heat is needed for separation.
I think it would be better to ask: Would be safe to use Blue Loctite on body mount bolts?
Here's why...
For now, I am doing a tub restoration, body and suspension lift. When I can financially afford to, I will be doing an engine swap and other updates that will be easier with the body off.
The tub restoration includes welding chunks of flooring that I had to cut out because 8 of the 10 body mount bolts snapped. Once the welding is done, the body mount nuts will no longer be accessible for heating.
So I'm leaning towards Blue Loctite because:
  • The tub will be coming off within the next two years.
  • According to the Red Loctite TDS, parts must be heated to 482F for separation.
  • Having installed a new 3" lift kit, I'm concerned that heating a very long, 1/2" bolt to 482F may take a while and in the process will damage the nylon lift blocks.
Thanks,
Chris
simspace is offline
post #4 of 7 Old 07-23-2013, 07:49 PM
rjbruzan
Ive worked on trucks and cars in the rustbelt for the last 40 years and I would use anti seize and not locktite. The only body bolts Ive seen come out are the ones that were left loose. If you are going to take it apart soon no locktite. I believe you are overthinking this.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is online now
post #5 of 7 Old 07-23-2013, 08:25 PM
jameslinn83
I second the anti sieze. Then check them for tightness after a couple rides. If they are still tight no worries.
jameslinn83 is offline
post #6 of 7 Old 07-23-2013, 10:15 PM Thread Starter
simspace
Awesome guys. Thank you!
I appreciate the advice.
Anti-seize it is.
-Chris
Chris S.
'94 YJ
'94 XJ
simspace is offline
post #7 of 7 Old 07-27-2013, 06:54 AM
ToledoDave
Factory body bolts have Green locktight on them. I also reccomend using antiseize and not locktight. If for what ever reason you cant remove the bolt your surely not going to cut open your floorboards to heat,cut,or replace the nut. The bolt wont come loose. The Isolator has a metal sleeve that tightens against the body and the bolt. If you locktight that bolt i def would not use red for reaons your not able to heat the nut without cutting the floorboard open.
ToledoDave is offline
