question on painting - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Paint and Body > question on painting
TERAFLEX JKU 2.5" Elite LCG Long FlexArm Lift Kit w/ March Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATEFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRI
Unread 12-16-2014, 05:25 AM   #1
my1986cj7
I have a jeep I'm wanting to paint now the jeep has been painted before with a one stage blue paint over the original gold paint. MY question is do I have to take it down to bare metal or can I just rough up the blue paint with some fine sandpaper and spray over the top of the two coats. The blue is not chipped but just faded and I want my jeep a different color.
my1986cj7 is offline   Reply With Quote Quick reply to this message
Unread 12-17-2014, 05:57 AM   #2
my1986cj7
ok I have another question which is better single stage paint urethane,enamel, or acrylic lacquer. I want a good paint job. Doesn't have to be show quality, but I'd like the best results as possible. This is on a trial rig so I want one that is durable. Also do I need to put a primer on a one stage paint if I just sand it down and repaint it. Thank you for any help.
Unread 12-18-2014, 09:53 PM   #3
Indy
Generally you only need to remove the gloss from the last coat so the next will stick. Primer will even the color so the finish is also even, but for basic paint its not needed. Base/clear will give better results than single stage, it also needs more prep work. Bad prep makes for bad paint. Single stage is a little more forgiving.
I'm the only gay eskimo.
Indy is offline   Reply With Quote Quick reply to this message
Unread 12-20-2014, 01:18 PM   #4
swirve
How does bc/cc require more prep work???
swirve is offline   Reply With Quote Quick reply to this message
Unread 12-20-2014, 01:27 PM   #5
swirve
If your just looking for a color change and there is no issues with the existing paint just sand it with some 800 dry on a DA or some 1000 wet. Remove all the gloss. Then follow up around the edges with some grey scotch brite.( I prefer not to wet sand because of the mess and the water getting into every crack. ) blow off, wipe down, tack off then apply your top coat. No primer is needed if you havent cut through anywhere. You can use bc/cc or s/s urethane. Either one will be a good choice. Each has is pluses and minuses. If youve never sprayed before id probably lean towards the bc/cc due to the fact that when you run it (yes you will) you can cut the run out of the clear without being noticeable. When you put a hanger in s/s more often than not it leaves a dark mark where it was. If your doing a metallic its almost mandatory for BC/CC if youve never sprayed before.
Unread 12-21-2014, 05:50 PM   #6
Indy
The glossier the finish will be the more minor flaws will show up in it. So it needs more prep work to be closer to perfect. Single stage will hide more flaws. Single stage matte (think grey primer) will hide EVERYTHING. One of the main reasons you want to be wary of buying anything with fresh primer that is being sold as "ready for paint". Odds are it's far from it.
Unread 12-22-2014, 05:45 AM   #7
my1986cj7
I know it's not recommended to shoot metallic paints as your first paint job but this is the color we picked so any advice for a first time painter besides trying to paint some other things first?
Unread 12-22-2014, 09:20 AM   #8
swirve
Horsecrap.
Unread 12-22-2014, 09:21 AM   #9
swirve
[quote="Indy"] The glossier the finish will be the more minor flaws will show up in it. So it needs more prep work to be closer to perfect. Single stage will hide more flaws. Single stage matte (think grey primer) will hide EVERYTHING. One of the main reasons you want to be wary of buying anything with fresh primer that is being sold as "ready for paint". Odds are it's far from
Unread 12-22-2014, 09:55 AM   #10
swirve
I need more info, what kind of set up do you have... Compressor, gun, positive air flow( booth) exhaust, heat, whats your climate, how much do you plan to spend, and quality.?
Unread 12-22-2014, 02:41 PM   #11
my1986cj7
60 gallon compressor with 12 cfm at 40psi cheap harbor freight gravity feed gun no booth and will be in the spring. In southeast Missouri. $500 in paint and primer the extras will be just that extras. And the best I can do in quality.
You can't fix stupid. If your going to be dumb you better be tough.
Unread 12-22-2014, 05:51 PM   #12
swirve
I think your gonna max the compresor especially doing a complete. Nothing wrong with DIY but i think youd be $$$ ahead and happier if you did all your own prep and bought materials then took it to an earl scheib or maacco and hired the painter to spray it.
