Proper primer for bedliner - JeepForum.com
post #1 of 5 Old 01-05-2011, 08:17 AM Thread Starter
jdlester73
I recently tried using Rustoleum's Truck bed liner. The surface was prepped really good but apparently I used the wrong primer as it blistered/bubbled once I applied the bed liner. A friend found that I used enamel primer and said that was the problem. He said since I used a wire wheel on my grinder and took it down to bare metal again that I wouldn't need a primer for this stuff since the metal is really scratched (the liner would grip). The directions say to prime but gives no indication of what type (hence my misfortune of using the wrong type). I like the bed liner and will use it again as it looks and feels great over the areas with the original paint on it, I just don't want to do this a 3rd time.
jdlester73 is offline
post #2 of 5 Old 01-05-2011, 09:44 AM
InfernoGirl
Call the # on the Rustoleum bedliner and ask them what to prime with.... Then if it fails they can pay you for more bedliner to do it again. Honestly, they will know better than anyone here what products work best together.
Dirty Mudder seat covers/Steering column covers/spare tire covers
Like my Dirty Mudder FB fan page here:
01 Jeep Wrangler Sport 4.0L, auto
Mine
07 2D Rubicon Flame Red His
InfernoGirl is offline
post #3 of 5 Old 01-05-2011, 10:35 AM Thread Starter
jdlester73
I will give that a try. I emailed the tech. support several days ago and haven't received anything back. Hopefully the phone lines give better service.
post #4 of 5 Old 01-10-2011, 06:52 PM
Red00Tj
enamel primer is kinda a double negative you don't want enamel primer because its shiny and the reason its shiny is because there is a small amount of clear coat substance mixed with it well paint/bed liner cant stick to clear coat so you have to use a FLAT primer i typically go to wal mart and get their cheap grey primer and it works great also if you really want i would rub the whole floor down with rubbing alcohol before priming jsut get it extra clean. i mean if your spending that much time and money whats another 10 mins and 5$? just to be safe. then spray primer and then bed line it send some pics im interested in the Rustoleum bed liner but not sure how it turns out as a finished product
(Rustoleum will tell you to use their primer but its the same basic thing as any cheap flat primer but it has their name so its ganna be more money) just FYI
Red00Tj is offline
post #5 of 5 Old 01-11-2011, 02:30 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Depending on what bedliner is used, you're dealing with different solvents that are part of the formula in each product.
Many general purpose primers can be attacked by the solvent that is in an automotive topcoat or bedliner in this case.
The OP had used Rustoleum Road Warrior which has a high content of Xylene (aka: xylol)
This solvent will attack a regular primer and blister as he described.
You need what is considered a "non-lifting" primer. 2 part automotive epoxy will work here.
Also if you have an industrial paint supplier near you, ask for a "phenolic modified" primer that won't lift under strong solvent.
These primers are only 1 part and easy to use. They can be brushed on and they dry fast to topcoat
Sometimes this type of primer is also called a "non-sanding" primer
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is online now
How much paint/primer to buy? AppFan Paint and Body 3 11-09-2010 07:14 PM
Uh-Oh (primer & prep mistake?) Lakeozark-YJ Paint and Body 1 09-17-2010 07:04 AM
primer paraman72 Paint and Body 2 05-31-2010 01:45 PM
Where to purchase primer and paint TRex Paint and Body 4 05-10-2010 08:37 AM
Rustoleum self etching primer. Can I spray urethane 2k primer over it? littleturner76 Paint and Body 1 10-11-2009 09:55 PM
