Primer for painted and bare surfaces - JeepForum.com
post #1 of 4 Old 01-07-2011, 07:27 AM Thread Starter
rompinthewoods
My question is about the U-Pol Raptor Liner. I am prepping my jeep tub to spray and I have areas of sanded paint and bare metal. Should I put a primer down or just go ahead and spray it? If I need a primer, what type?
If I have to drill out another bolt, I'm just going to start welding parts on.
rompinthewoods is offline
post #2 of 4 Old 01-09-2011, 01:06 PM
slowlowford
I would call the company, but I usually use epoxy primer over bare metal sometimes an acid etch primer. In your case I would probably use the epoxy.
4bt,NV4500,NP205 Twin,Soa,8.8, 4.88's locked front and rear
slowlowford is offline
post #3 of 4 Old 01-11-2011, 10:10 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Def go with epoxy. Etch primer will not stick correctly to the surrounding painted areas. Epoxy will go over all with no problem.
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #4 of 4 Old 01-12-2011, 07:23 AM Thread Starter
rompinthewoods
Thanks guys. I definetely do not want to be doing this again in a year or two.
How much paint/primer to buy? AppFan Paint and Body 3 11-09-2010 07:14 PM
Epoxy Primer/sealer mark12010 Paint and Body 15 09-26-2010 04:15 PM
Uh-Oh (primer & prep mistake?) Lakeozark-YJ Paint and Body 1 09-17-2010 07:04 AM
primer paraman72 Paint and Body 2 05-31-2010 01:45 PM
Rustoleum self etching primer. Can I spray urethane 2k primer over it? littleturner76 Paint and Body 1 10-11-2009 09:55 PM
