Primer ?? - JeepForum.com
post #1 of 8 Old 06-15-2012, 06:42 PM Thread Starter
gator4ever
1978 CJ7
Primer ??
Will applying a coat of black primer help me achieve a more uniform paint job? My jeep/hunting buggy has some scratches and dents that I have fixed with Bondo.
I was thinking that the black primer will get the entire jeep the same color then I can paint it.
any thought??
gator4ever is offline
post #2 of 8 Old 06-15-2012, 08:33 PM
Ironworker709
Ironworker709's Avatar
Its always a good idea to primer all one color before spraying the color coat,if not,,yes,,it can easily cause different shades here and there.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #3 of 8 Old 06-16-2012, 07:44 AM Thread Starter
gator4ever
1978 CJ7
Thanks iron worker. Would black be my best choice for a primer color?
post #4 of 8 Old 06-16-2012, 07:59 AM
Ironworker709
That always depends on the color you are spraying..some colors will even come with a tech sheet that says the best option for a certain color primer for easier/better color coverage.
For example,I used a VW Metallic Reggata Blue for a project and it said to specificaly use a black primer to acheive the best shade and coverage it was intended to be.
But as far as camo colors,flat/semi colors..etc or just an enamel or such..grey is usualy the most used since it's the most common available.....
Black or grey will work on just about anything,unless your looking for a specific exact match of a color your shooting for...
But
Never forget 9/11
post #5 of 8 Old 06-16-2012, 08:09 AM
YJgearhead89
That's a good point, DuPonts brand use ratings for the individual colors. For the Chromasystem they use values of 1-7 from white to dark gray that correspond to the sealer coat to use under the color like Ironworker said.
Now if you're new to painting and aren't familiar with this or you're using just rattle cans for a cheap paint job, then any primer would color would work. I don't think I saw anything that said what color you we going with. Now that would have a lot to determine what you should use.
Sent from my phone because I should be doing something else right now
YJgearhead89 is offline
post #6 of 8 Old 06-16-2012, 01:56 PM Thread Starter
gator4ever
1978 CJ7
I am going to paint my jeep OD Army green. I would imgaine that grey would probably work better than black ?
post #7 of 8 Old 06-16-2012, 07:41 PM
Ironworker709
You'll be fine with the black if thats what you already have..the army OD green is a high solids color..great color coverage
Never forget 9/11
post #8 of 8 Old 06-17-2012, 10:47 AM Thread Starter
gator4ever
1978 CJ7
That is what I need coverage to cover the screw ups from 34 years of running it in Florida swamps.
What to do with Jeep frame - por-15 or primer (and what primer) Benmack1 Paint and Body 9 07-28-2011 04:00 PM
sprayed some primer b-dog Paint and Body 5 04-12-2011 03:17 PM
POR 15 Primer? Scarabotti95YJ Paint and Body 2 02-12-2011 10:10 PM
primer paraman72 Paint and Body 2 05-31-2010 01:45 PM
Rustoleum self etching primer. Can I spray urethane 2k primer over it? littleturner76 Paint and Body 1 10-11-2009 09:55 PM
