POR15, Chassis Saver, or Rust Bullet? - JeepForum.com
post #1 of 8 Old 04-18-2013, 08:59 AM Thread Starter
kyrubicon
1980 CJ5
Here's the dilemma. I just sand blasted and powder blasted my entire 1980 CJ. Now I need to put some paint on it after I repair a couple wholes in the body and frame work. What is the best thing or who has had what kind of experience with each of these products; POR15, Chassis saver, or Rust Bullet? I am looking to make body and frame repairs then spray bottom asap to prevent any more rust from comming back. Anything else you could recommend would be great as well to keep preventing rust in the future. thank you.
kyrubicon is offline
post #2 of 8 Old 04-18-2013, 11:46 AM
CJuncky
1981 CJ5
After cleaning I sprayed mine with epoxy primer and then an industrial paint recommended by the paint store. It was a lot cheaper than the Por15. I did use Por15 on the frame.
Sent from my DROID RAZR HD using JeepForum
81 CJ5 258/T18/dana20/ARB locked diffs/33's
80 CJ7 258/auto/d 44 diffs/ 4" lift/rebuild started 80 CJ7 #2 stock(sold)
82 CJ7 stock DD
CJuncky is offline
post #3 of 8 Old 04-18-2013, 02:17 PM
rjbruzan
X2 on the epoxy primer and a quality automotive paint,acrylic enamel or urathane. This will last the longest.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #4 of 8 Old 04-18-2013, 06:41 PM Thread Starter
kyrubicon
1980 CJ5
Great. Thank you for your alls help. Will look into tomorrow at the store.
post #5 of 8 Old 04-18-2013, 06:46 PM
insaneinline
Check out kbs frame coater its like Por 15 and the rest of them but you can get the whole frame kit for like 80 dollars
insaneinline is offline
post #6 of 8 Old 04-24-2013, 04:40 AM
TJJeepJosh
I used chassis saver on the front and back parts of my frame as well as under my tub and skid plate. I love it so far. Its easy to put on, just sand down the really rough stough and it goes right over anything else. Seems to be lasting too. I also found some stuff from eastwood that would help the inside of the frame. Not sure how easy it would be to do or if its even worth it but seems interesting.
http://www.eastwood.com/internal-fra...ay-nozzle.html
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline
post #7 of 8 Old 04-24-2013, 04:24 PM
222Doc
222Doc's Avatar
Self ecthing bare metal primer, epoxy is best. But the metal should be preped with a metal conditioner first. I have used a Dupont product its an acid/alcohol/ you mist it on the metal turned a bluish color. Then hit it with etching primer. It could sit from there with out rusting. Bare metal will start to rust the secound it hits the air.
222Doc is offline
post #8 of 8 Old 04-30-2013, 09:37 AM
braguenavy
I used POR-15 on my frame and under body of my jeep. Its been through two harsh winters up here in PA and still has a gloss black shine under the whole jeep and frame.
braguenavy is offline
