Painting Stainless Steel - JeepForum.com
post #1 of 3 Old 10-30-2013, 09:15 AM Thread Starter
Mike86CJ7
Anyone successfully paint stainless steel? (CJ hinges in this case.) I've read everything from hitting it with a scotch brite pad, to 200 grit sandpaper, to wiping it down in a mild acid solution. I've even heard Easy Off oven cleaner would work to give the paint something to stick to.
I'd like to hear what you used successfully. Thanks!
1986 CJ-7: Fiberglass tub, 5" total lift, 33x12.5 M/T's, 258, Weber, T5, Dana 300, Dana 44 rear
Mike86CJ7 is offline
post #2 of 3 Old 11-01-2013, 04:39 PM
Ironworker709
Ironworker709's Avatar
There is really no difference in painting mild steel and stainless..most think its a different situation because alot of stainless parts are polished so they always "assume" its just as hard to paint and keep it on there as a chrome finish...but it is not...
if it's polished..hit it good with a 220 grit to get give it a good adhesion surface and go about painting it with a good primer and top coat as you would anything else...
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #3 of 3 Old 11-01-2013, 08:30 PM Thread Starter
Mike86CJ7
Sounds good. Thanks for your response!
