Painting with Rustoleum spray cans... - JeepForum.com
post #1 of 10 Old 09-01-2012, 12:53 PM Thread Starter
thejafe
thejafe's Avatar
I'm in the process of coating my new Rokmen gas tank skid and rear bumper. I sanded the bare metal with 400 grist then cleaned everything with acetone first. Hit it with a few coats of Rusto Self Etching Primer then a wet sand with 400 grit again.
Now that I'm ready for the top coat I'm looking for some tips on getting a quality finish . Will be shooting Rusto Semi-Gloss. Is it ok to put on a few coats then wet-sand when it's fully cured, and then hit it again?
thejafe is offline
post #2 of 10 Old 09-01-2012, 01:02 PM
Nightstr
1969 CJ5
Dupli color spray paint works the best in my opinion. I hit my tacomas played feont bumper with aome dupli about two years ago now and it still looks good.
Nightstr is offline
post #3 of 10 Old 09-01-2012, 06:12 PM
Ironworker709
Ironworker709's Avatar
Just spray it in several light coats,no need to sand in between coats if done within the same day....the common rustoleom will cure enough in 15 minutes to 1/2 hour for recoats...it best to get all coats on before fully cured,for the fact your getting a "chemical bond" verses a "machinical bond"
I the case of needing a good tough enamel,i prefer rustoleum over dupli-color,its a much tougher product
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #4 of 10 Old 09-01-2012, 08:06 PM Thread Starter
thejafe
thejafe's Avatar
Interesting point about chemical vs mechanical bond. Never considered that. With this project I did four coats of black over the self etching primer. Not totally satisfied with the coverage and would like to hit it again. Tomorrow night the required 48hrs will be up for drying. Think I should give it a wet sand at this point or just spray away?
thejafe is offline
post #5 of 10 Old 09-01-2012, 09:23 PM
Ironworker709
It would never hurt to sand it again,if anything not sanding it could be a downfall,so sanding it again would be extra insurance
Never forget 9/11
post #6 of 10 Old 09-01-2012, 09:53 PM Thread Starter
thejafe
thejafe's Avatar
Alright, thanks for the info. Will give it a shot.
thejafe is offline
post #7 of 10 Old 09-11-2012, 05:05 PM
seattle_yj
How did this turn out? Any Pics?
seattle_yj is offline
post #8 of 10 Old 09-16-2012, 02:47 PM Thread Starter
thejafe
thejafe's Avatar
Hey, sorry it took me so long to post some updates . So far I've painted:
Rokmen Rear Bumper
Rokmen Gas Tank Skid
Rokmen Sliders
I started all of these parts off with an acetone wipe-down, 400 grit sanding, then another acetone wipe-down. I then shot everything with Self-Etching Primer, followed a few minutes later by the first coat of Rusto Semi-Gloss Black. I went with several light coats a few minutes apart, then when I had everything totally covered with Semi-Gloss Black I let it all dry for 48hrs. With the size of these parts it's difficult to get nice, even coverage so after the 48hr dry time I inspected everything closely. If I felt as though I didn't have enough coverage in a certain area I lightly sanded with 400 grit, wiped clean then shot another layer or two of paint.
For all of these parts I must have used 8 cans of Rusto Semi-Gloss plus maybe 6 cans of the primer. Started getting expensive . It's a time consuming process due to the drying times but if you're patient and do it right you'll get good results : . Also, get yourself one of the grip attachments like in the pic below. Makes a HUGE difference and it's only $7. Your finger will thank you!
Next up will be painting my rims with Rusto wheel paint :
thejafe is offline
post #9 of 10 Old 09-16-2012, 06:50 PM
seattle_yj
oh nice! looks awesome.
I have a question about the hardness of the paint. How long did you have to wait until the paint fully hardened? I painted a couple items a few weeks ago, with I believe the same kind of paint, and even after a week of drying it still seems to scratch pretty easily. Then maybe after two to three weeks, it seemed pretty hard. What was your experience with the hardening process?
post #10 of 10 Old 09-16-2012, 09:12 PM Thread Starter
thejafe
thejafe's Avatar
I've heard that it takes weeks for the paint to fully cure but don't have any solid facts on that. I painted my GenRight front bumper using the same method last summer and it's held up VERY well. I haven't scraped it across a rock or bashed it into anything yet though. Either way, I don't expect any paint to remain if any of these parts encounter rocks/trees etc. But that's the great thing... just break out the spray can and cover up.
thejafe is offline
Rustoleum for painting! Bradman96 Paint and Body 2 09-21-2011 12:22 AM
Rustoleum Truck Bed Spray...... crazyak Paint and Body 7 03-27-2011 09:15 PM
Rustoleum hammered spray can mbarrett1102 Paint and Body 10 03-24-2011 08:03 AM
Re-painting a spray can job CTeunuch Paint and Body 4 07-29-2010 10:53 PM
Rustoleum self etching primer. Can I spray urethane 2k primer over it? littleturner76 Paint and Body 1 10-11-2009 10:55 PM
