Hey guys ordered my self a PSC pre welded cage, it ships in raw steel. I have purchased Montana black spray paint, not that it matters but color is olive green. Anyway what is the best way to go about preping and painting?
first thing is remove any glue or stickers then degrease. sand the whole cage with 150 and then wipe with grease and wax remover. prime. since you are doing a dark color use a dark primer like black. them paint acording to the paint and primer coat times. clear if desired.
I always wipe steel with some acetone after sanding it to clean the surface. Then prime and paint. I normally do 2 coats self-etching primer then enough coats of paint to get the job done.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
