painting door panels??? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Paint and Body > painting door panels???
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! April Instant Rebate: Up to $75 off Flowmaster Products!
Unread 02-18-2015, 10:41 AM   #1
PistolPete65
So my panels are jacked up. I was wondering has anyone ever painting them?
If so what did you use or steps to make it right? Thanks in Advance
PistolPete65 is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 02:59 PM   #2
turpehar
turpehar's Avatar
1977 CJ5
Take them off. Wash with soap and water. Wipe them down with wax/grease/silicon remover. Scuff with purple scotch brite pad. Wipe down with wax/grease/silicon remover. Spray with krylon fusion. Or you could go to the paint store and buy the OEM paint. Just a time taker, nothing difficult.
I've been married so long I don't bother looking
both ways before crossing the road.
(Trial + error)*Upgrades) - $≤ = (mac-n-cheese/hot dogs)+experience
http://www.facebook.com/CentralILOffRoad
http://centraliloffroad.com/
turpehar is offline   Reply With Quote Quick reply to this message
Unread 02-19-2015, 03:48 AM   #3
PistolPete65
Thank you. I'll do it then post the before and after pictures here.
Unread 02-19-2015, 08:50 AM   #4
swirve
Dont use wax& grease remover on plastic parts. Use de natured alcohol. The wax&grease remover will pull the mold release agent out of the plastic.
swirve is offline   Reply With Quote Quick reply to this message
Unread 02-21-2015, 02:59 AM   #5
PistolPete65
So my plan of action is :
Take them off. Wash with soap and water. Wipe them down with de natured alcohol.. Scuff with purple scotch brite pad. Wipe down with de natured alcohol.. Spray with krylon fusion.
Sounds good to me.
Unread 02-22-2015, 01:44 AM   #6
dwsutton
David- Redneck Garage
dwsutton's Avatar
I use SEM Color coat or Color Bond here is their detailed instructions -
http://www.colorbondpaint.com/blogs/...gged/colorbond
David - The Redneck Garage
http://www.theredneckgarage.org
Redneck Garage Youtube Channel
http://www.youtube.com/user/dwsutton
dwsutton is offline   Reply With Quote Quick reply to this message
Unread 02-23-2015, 09:20 PM   #7
turpehar
turpehar's Avatar
1977 CJ5
The mold release agent is not mixed in the injection. The release agent is applied directly to the mold.
Again, not looking to argue but I paint nothing without using a silicon remover.
Unread 02-23-2015, 09:29 PM   #8
swirve
Originally Posted by turpehar
The mold release agent is not mixed in the injection. The release agent is applied directly to the mold. Again, not looking to argue but I paint nothing without using a silicon remover.
That may be but you dont use a dedicated wax& grease remover on plastic. It will draw the oils out. Denatured alcohol is what is needed to be used on plastic.
Unread 02-23-2015, 10:21 PM   #9
turpehar
turpehar's Avatar
1977 CJ5
Here is my dedicated opinion.
for 30 years I've heard conflicting advice about which type of wax and grease remover is best and the difference between solvent-based and alcohol-based cleaners.
Wax and grease removers are solvent-based liquids, which are refined from petroleum. The solvent is readily absorbed into raw plastic. Raw = un-primered
Alcohol based (distilled from grain) wax and grease removers arenít easily absorbed into the plastic because they flash to0 quickly to do really good cleaning, so I recommend solvent cleaners even on raw plastic. Wipe on and wipe off immediately. That is key, don't let any solvent sit wet on plastic. Wipe it off with a clean cloth.
In addition a plastic adhesion promoter is worth the extra dough.
I'm not arguing, just sharing my experiences.
