Paint Job - JeepForum.com
post #1 of 19 Old 11-13-2013, 08:45 AM Thread Starter
Carson7
1987 YJ Wrangler
Paint Job
About how much would it cost to get my 87 YJ painted?
Carson7 is offline
post #2 of 19 Old 11-14-2013, 03:29 AM
SunDevilJeeper
That all greatly depends on who you go to, and what extent you want it done. Some people can do it for $300, some shops will charge upwards of $5000 for their full package.
All depends on who you go to. Or you can just rattle can it and do it yourself for $40-60!
Call the paint shops where you live and ask.
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #3 of 19 Old 11-15-2013, 09:35 AM Thread Starter
Carson7
1987 YJ Wrangler
Originally Posted by SunDevilJeeper
That all greatly depends on who you go to, and what extent you want it done. Some people can do it for $300, some shops will charge upwards of $5000 for their full package. All depends on who you go to. Or you can just rattle can it and do it yourself for $40-60! Call the paint shops where you live and ask.
Thanks. Hopefully I can get to that soon
Carson7 is offline
post #4 of 19 Old 11-15-2013, 09:36 AM
Itstime
Also would you want to monster line it or use normal paint? Do you wheel it a lot?
Itstime is offline
post #5 of 19 Old 11-15-2013, 08:37 PM Thread Starter
Carson7
1987 YJ Wrangler
Whats the difference in the two? It needs some work done, mostly to the rear end before it would be able to. If I can find somewhere close enough I'd like to
Carson7 is offline
post #6 of 19 Old 11-15-2013, 10:06 PM
Itstime
Monster liner is like bed liner but it comes in many colors. You can aslo get mat and gloss. It is a lot more durable I think it migbt weight a bit also. I have my cj interior sprayed with it.
Itstime is offline
post #7 of 19 Old 11-15-2013, 10:24 PM
Itstime
Itstime is offline
post #8 of 19 Old 11-15-2013, 11:23 PM
SunDevilJeeper
Use Monstaliner on your Jeep, and you'll never need another paint job ever again.
If you're wanting something that looks like the factory style smooth finish, gloss paint, you'll want a shop to do it for you.
Something cheap that looks "good enough" like in the case of many people, and is easy to touch up like bed liner? Rattle can.
Like already asked, do you wheel it a lot? Or do you anticipate any blemishes in the paint that would warrant a touch up? If so, the bed liner or rattle can is the better route to go.
post #9 of 19 Old 11-16-2013, 01:06 PM Thread Starter
Carson7
1987 YJ Wrangler
Thanks for the clarification. Any other tips that may help?
Carson7 is offline
post #10 of 19 Old 11-16-2013, 05:32 PM
Itstime
Never let a guy paint it unless you have seen some of his work my cousin had a guy paint it for half the cost a shop would and lets say he did not get a good deal...
Itstime is offline
post #11 of 19 Old 11-16-2013, 07:58 PM
SunDevilJeeper
On top of that, I would ask what they do during the painting process. Or rather how they repaint a vehicle.
If they don't go into detail about it, then that would be a red flag for me. If they just say they sand it down and repaint it, I'd keep looking.
Somebody that tells me they go through all the stages, talks about their techniques, and even talks about what kind of primer, paint, and clearcoat they use, and how many coats, then I'd be more likely to pay them to do it.
post #12 of 19 Old 11-16-2013, 09:53 PM Thread Starter
Carson7
1987 YJ Wrangler
I didn't think about that. Great point. Also:
1.) The rear sway bar was cut on one side I assume it was to accommodate the lift. Can that be a problem?
2.) There is a clicking sound somewhere under the hood. Possibly a loose belt?
Carson7 is offline
post #13 of 19 Old 11-16-2013, 11:05 PM
Itstime
Just on one side?
Itstime is offline
post #14 of 19 Old 11-16-2013, 11:07 PM
SunDevilJeeper
Don't worry about the sway bar, leaf spring vehicles don't really need them all that much. I, along with many other people, have removed the track bar and sway bars. Usually the YJ will ride better without them. They aren't necessary, just something to get the NHTSA to shut up mostly. On a vehicle with coil springs, yeah you should probably have them on, otherwise you're in for a fun time when you turn at intersections.
The clicking sound could be several things. It could be an exhaust leak at the manifold, which isn't hard to fix. It could also be valves which isn't cheap to fix depending on who's doing it. I've seen worn out and wobbly pulleys make clicking noises before, not on Jeeps but on other vehicles.
You'd have to stick your head in there and try to pinpoint the location for us to be able to tell you accurately. Then again somebody will probably come along who knows what the problem is with just that bit of information.
post #15 of 19 Old 11-17-2013, 07:38 AM Thread Starter
Carson7
1987 YJ Wrangler
Cool thanks
Carson7 is offline
