Paint exterior or spray liner on interior first? - JeepForum.com
post #1 of 8 Old 04-28-2013, 10:23 PM Thread Starter
monster78
Good evening! I have been reading this forum for years and have gained a wealth of knowledge by taking time to search and read. I am currently restoring a Scrambler and have almost completed the bodywork inside and out. I am looking for opinions from everyone for what to do first. Should I spray the liner inside or paint the exterior first? Thanks!
monster78 is offline
post #2 of 8 Old 04-29-2013, 03:45 PM
Zone
I would say bedliner first for the interior, then paint the exterior.
If you paint first, you will have to mask off the painted surface to prepare to spray the bedliner which means you will be placing masking tape on the new paint. If you happen to find a weak spot in the paint (or primer), the masking tape may pull off your new paint.
Zone is offline
post #3 of 8 Old 04-29-2013, 05:12 PM
rjbruzan
I would say the opposite as getting overspray off the bedliner will be tough. I would paint first and do the liner second. Roll or spray will determine how much masking is needed.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #4 of 8 Old 04-30-2013, 07:30 AM
Zone
It's easy to mask off the bedliner and it's not going to come off with tape.
Zone is offline
post #5 of 8 Old 05-09-2013, 06:55 PM
tybota
Bedliner then paint... my 2 cents
tybota is offline
post #6 of 8 Old 05-14-2013, 08:56 AM
Jims-87YJ
1987 YJ Wrangler
I think it depends on where you want the Bedliner to end up. When I did mine I did bedliner onto the door sills to prevent scuffing the paint. In this case it would have been very hard to tape the bedliner and then paint and get a nice crisp line. SO I painted the exterior first then applied the bedliner (Monstaliner), see by build thread. Good luck!
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #7 of 8 Old 05-15-2013, 08:25 AM
Indy
Indy's Avatar
Interior then exterior.
I'm the only gay eskimo.
Indy is offline
post #8 of 8 Old 05-16-2013, 08:59 AM
Ironworker709
Ironworker709's Avatar
It doesnt metter either way if you do a nice tape job.
i prefer paint first,then bedliner...its easier to get the crisp lines with the bedliner than it is to paint lines overlapping a bedliner..just looks much better
Fresh paint will not come off with paint tape unless the paint didn't adhere right in the first place as long as you let it cure to its required cure time..............unless your using a cheap paint with no hardener and takes weeks to cure........
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
