Need help! Rust Repair for a '85 CJ7 - JeepForum.com
post #1 of 12 Old 09-07-2010, 06:42 PM Thread Starter
TylerCJ7
I just bought my first vehicle with my own money, a '85 CJ7 with a 258 and a 4 Speed. It runs good, except for my clutch slipping (getting fixed) and my floor needs some repairs. Does anyone in the Hampton Roads area know of any places that would repair my tub? Would Maaco or Hall Automotive Collision Center do it? I honestly don't have the money to buy a new tub, and honestly the rust doesn't look that bad in this. Give me opinions or suggestions guys. I honestly don't care about what my jeep looks like color wise, I just want my tub fixed. Thank you for whoever replies.
The first 2 pictures are from behind the driver's seat.
The 3rd picture is from the front of the passenger seat.
The 4th picture is from behind the passenger's seat.
Driver Side Behind Seat.JPG   Driver Side Behind Seat 2.JPG   Passenger Side In Front.JPG   Passenger Side Behind Seat.JPG
TylerCJ7 is offline
post #2 of 12 Old 09-07-2010, 07:08 PM
rclark678
I see you mentioned places but do you know anyone with a welder? I had that same issue on my 84 CJ7 I just bought. I/we cut the metal till we got to good metal approx 4x6 area under each side of roll bar and up the back kick pan. For an added bonus to my issue's I also had some small rust holes in the rear floor pan and just cut the whole thing out and bought a new one. Now I am rust free! Good luck and congrats on the Jeep!!
rclark678 is offline
post #3 of 12 Old 09-07-2010, 07:09 PM
brownbagg
1930 MK Compass
under neigh the roll bar is gone, under the seat belt holder is gone, floor boards is gone and proberly the side under "Jeep" and at the rear by seat belt holder on outside. they all rust here. most is because somebody had carpet in it. I got four in my yard that all have this same problem.
but it easy to fix, and no dont take it no where. do it yourself, what cant do it. wrong answer , do it yourself anyway. take it some where, they will charge you 65 dollar a hour for about 25 hours. So do it yourself. Go harbor freight buy you a jigsaw, a small grinder, some cardboard and if you are brave. a small welder.
trace a pattern on cardboard, cut the metal with the pattern and either, bolt, pop rivet or weld. cant weld, well it about time you learn, and what a better way.
still cant do it, then sell the jeep and buy a chevette
brownbagg is offline
post #4 of 12 Old 09-07-2010, 07:31 PM Thread Starter
TylerCJ7
Do you guys know if it'd be worth the money to buy the Quadratec stamped floor pan replacements? I'm thinking MAYBE for the rear, but I'm questionable about the front.
TylerCJ7 is offline
post #5 of 12 Old 09-07-2010, 10:03 PM
mikeumkc
2009 JK Wrangler
what I would do......
there is only rust THROUGH in a couple areas. I would save up some money to do it right down the road. For now, I would get some phosphoric acid (home depot sells it in the paint department). Spray that on any of the rusted areas. What it does is convert iron oxide (rust) to ferric phosphate. ferric phosphate is black in color and hard as a rock. It wont rust in that spot again. At that point, you can paint it or just leave it how it is.
I did this myself on the jeep I JUST bought last week. There were quite a few areas of rust in the floor pan (only one quarter sized hole). I took out all the interior, just a few bolts, and sprayed the acid over any rusty area. let it dry overnight. its solid as a can be. I'm going to hurculine the inside of the tub next weekend.
I'd recommend this to anyone on a budget.
2009 JKU Rubicon. stock now.... I'm working on it.
mikeumkc is offline
post #6 of 12 Old 09-08-2010, 06:15 AM
rclark678
I'm not sure about quadratec, but I bought one off Ebay for $50 bucks 18ga all total. Get a good spot weld cutter and go to town. Took about a good day to actually get it out, and another to put it in.
done
post #7 of 12 Old 09-08-2010, 09:01 AM
knowlwk@snowhill.com
1980 CJ7
mikeumkc, don't herc over the rust man.. you'll just create more work for yourself. The rust will continue under the herc and one day you'll fall through. That's the good part... the bad part is that when you go to fix it, you'll have to remove the herc and that is a total nightmare. Ask me how I know... LOL
'80 CJ7, 258 W/Autojuicer, MC 2100, TFI, SummitRacing CDI, MORE SRS, Moser 1-pc, YJ tub on 1" body lift, YJ family cage.
knowlwk@snowhill.com is offline
post #8 of 12 Old 09-08-2010, 02:46 PM
mikeumkc
2009 JK Wrangler
I agree with your 100%. Thats why I neutralized the rust with the phosphoric acid (OSPHO is a popular brand). Then I will herculine it and I have some por-15 left over from something else that I'm going to put on the underbody of the jeep. At least the parts I can get to without taking the body off.
mikeumkc is offline
post #9 of 12 Old 09-08-2010, 03:37 PM Thread Starter
TylerCJ7
Thanks for the responses guys. I know how to weld, its just I need to see if I can rent one from Home Depot. I've got one question though, how far would this floor reach?
Orignal Replacement Parts Floor from Quardatec
Also, would this help too?
Replacement Steel Step Brace
TylerCJ7 is offline
post #10 of 12 Old 09-08-2010, 06:02 PM Thread Starter
TylerCJ7
I just came up with an ingenious idea...can I fiberglass the holes I have?
TylerCJ7 is offline
post #11 of 12 Old 09-08-2010, 06:38 PM Thread Starter
TylerCJ7
Forget it, I think i'll just go get a floor. ):
TylerCJ7 is offline
post #12 of 12 Old 09-08-2010, 07:29 PM
kavephish
1981 CJ5
From my own experience, once you start grinding away at the rust, especially under the roll bar, you will find that the cancer extends well beyond just the floor. Fiberglassing will not work well in arears where structural support is required, unless you reinforce it with metal and use a dung load of fiberglass. You'd be better off swapping the old tub for a rust free YJ tub. You can probably get one cheaper than all the panels and materials you will need to patch the old one back together.
kavephish is offline
Body Rust Repair freeskier93 Paint and Body 10 05-01-2015 01:36 PM
rust.... what should i do? CoolGuyDave Paint and Body 15 07-21-2010 04:15 PM
Advice on repair (clearcoat / rust) CheetoWK Paint and Body 1 06-28-2010 02:40 PM
Why so much Rust? turkish6 Paint and Body 14 11-13-2009 01:15 AM
Proper way to repair a rust spot w/ paint and clear... ISUzj Paint and Body 9 11-11-2009 09:03 AM
