Need advice on paint - JeepForum.com
post #1 of 10 Old 09-06-2012, 10:01 PM Thread Starter
ferreira210
2008 WK
I have a couple concerns. I found a rust spot on my truck but on the roof. Should i get just that little part painted. or should i paint the entire truck. its a black 2008 grand cherokee diesel. please any advice helps thanks!!
ferreira210 is offline
post #2 of 10 Old 09-06-2012, 10:07 PM
swaugie
2011 JK Wrangler
if the rest of the truck still has the factory paint on it, my suggestion would be to leave it alone. generally speaking, the factory paint is much better than even a brand new paint job out of the finest of body shops. the clearcoat is much harder from the factory and will hold up better to being wetsanded and buffed. jmho.
swaugie is offline
post #3 of 10 Old 09-07-2012, 04:28 AM
Ironworker709
Ironworker709's Avatar
I'd sand and paint the whole roof itself..easier to blend in with the body lines...if you just do a spot or 2 it'll stick out like a sore thumb.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #4 of 10 Old 09-07-2012, 04:33 AM
Ironworker709
If you just leave it alone you'll be cutting out and replacing rotted sheetmetal,making for a very expensive job..............
The factory paints on any vehicle is the same exact paint that can be bought over the counter at any auto body supply store....no difference what so ever..................
Never forget 9/11
post #5 of 10 Old 09-19-2012, 01:22 PM Thread Starter
ferreira210
2008 WK
thanks for the advice guys
post #6 of 10 Old 09-27-2012, 09:20 PM
Doctor7474
It's not the paint that is different it's the curing procedure. In the factory they paint and cure the body in ovens at much higher temps and longer periods of time than you can in any body shop because the factory does this before putting on all the rubber and plastic bits that would melt in the baking process. This produces a much harder material than you could reproduce in a paint booth with a fully assembled vehicle.
Most body shops now a days will not do a complete respray for anything less than a small fortune (and if they do its going to be a Maaco job) as they don't want the head ache of dealing with the customer coming back because the quality is not up to the original.
Never touch factory paint if you can help it.
Doctor7474 is offline
post #7 of 10 Old 09-28-2012, 07:05 AM
Ironworker709
Baking the paint only speeds up the curing process so the vehicle can be assembled quickly,baking it on has nothing to do with durability....it's still the same exact coating...........whether it was baked on,or air cured,its still the same exact blend of paints.........
If you'll do your research a lil more,you'll find out coatings that take longer to cure are tougher in the long run once fully cured............
And thats the first i've ever heard of a body shop not wanting to do a re-coat because they fear the customer will come back because it would supposedely be less quality than an assembly line paint job..it's quite the opposite...assembly line coatings are just above average at best compared to a quality coating put on by a professional.....
If high production factory paint jobs were so great,then why do you see so many factory paints fail in a few short years compared to a quality paint by a body shop or body man?.............
I'd put my own work with a good Epoxy primer..good base coat and good clear coat up against any of the high production paint jobs any day.......
Never forget 9/11
post #8 of 10 Old 03-05-2013, 08:52 PM
swaugie
2011 JK Wrangler
I'll take your word for it but my experience working as a detailer was much different. Factory paint was much easier to work with and didn't take anywhere near the effort the cars coming out of the body shop did.
swaugie is offline
post #9 of 10 Old 03-06-2013, 01:41 AM
Ironworker709
The tougher the paint,the harder it is to sand and buff out......
Never forget 9/11
post #10 of 10 Old 03-10-2013, 09:41 AM
lobukjeep
Back in the day alot of it was what clear you were using to spray with.We would spray with that old dupont 7500s in the yellow can and it was horrible.Hard as a rock..Then we got the 7600s and it was much better.Lets not even mention IMRON..Then as the years went on i think think technology caught up and everybody had a decent product.I like PPG myself..I would just have the roof fixed and like Ironworker said ..they can just paint the roof and blend into the quarters.Easily enough done if you are a half knowledgeable painter.
"We don't call you son 'cause your bright"
lobukjeep is offline
Advice on body paint garretj64 Paint and Body 9 04-02-2012 10:11 AM
I need exterior paint advice kosterman83 Paint and Body 5 03-27-2012 11:18 AM
Any advice on paint shops in CT? 99tjusmc Paint and Body 0 03-30-2011 11:18 PM
paint guru's advice Anonymous6915 Paint and Body 37 09-08-2010 05:02 PM
advice on garage paint job Karub Paint and Body 26 07-20-2010 11:38 AM
