My rolled on paint job - Page 8 - JeepForum.com
post #106 of 116 Old 02-17-2014, 10:25 AM
BrianP789
One quick tip I haven't seen mentioned in this thread... Grounding whatever panel you're working on will help prevent dust in the paint by eliminating static electricity. You can do this simply by cleaning an inconspicuous spot to bare metal with a dremel or something similar, and attaching a length of chain in any convenient method (nut and bolt, alligator clip, even a magnet, you just need good clean metal to metal contact). Let the chain tail lay on the floor wherever you're working. Not going to make your $100 paint job a $1000 paint job, but it does help, especially in a dusty garage.
BrianP789 is offline
post #107 of 116 Old 02-17-2014, 12:18 PM Thread Starter
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
By my own admission I am no painter and I do recognize that dust is an issue but isn't it more of problem deal when you spray the paint?
One thing about the rolled on paint job if done indoors is there is little air movement Since no sprayer is involved. BUT, if grounding the body which is easy enough to do, might improve the finish... I say ground it baby!!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #108 of 116 Old 04-02-2014, 04:59 PM
hardluk
1987 YJ Wrangler
So how's this paint holding up? Any signs of a needed recoat?
hardluk is offline
post #109 of 116 Old 04-02-2014, 05:54 PM Thread Starter
laybackman
laybackman's Avatar
2010 JK Wrangler
The paint has held up well! It doesn't get washed unless it rains. For the cost of the paint, and it's reputation, the Rustoleum Topsider paint was a great choice.
There are other brands of paint that would probably work just as well. I chose it for what I knew about the brand already and it was sitting on the shelf at my local home cheapo!
post #110 of 116 Old 05-20-2014, 08:11 PM
gps4
1981 CJ7
Originally Posted by laybackman View Post
I have been thinking about the HT color. It was the factory spice color and I found it to be a bit to 'orangy' now that the body color was very light. My first thought was to go with satin of flat black. That would have worked but the wife thought that a color that was very close to what the spice looked like but a bit less 'orangy' would be nice.
So off to Home Cheapo to look at what the had on the shelves. I grabbed a quart of Rustoleum Painter's Choice Nutmeg # 240284 latex based paint. It is very close to the stock color but has little if any 'orangy' in it.
I cleaned the top with a little soap and much water. I let it dry out in the sun for a day then painted it the next day. I used a 4" roller and a foam brush. One coat later and I am happy with the sutble change to the top color.
And with my JF sticker!
Up close.
Did you have to thin the paint for the hardtop, or just roll it on right out of the can?
gps4 is offline
post #111 of 116 Old 05-20-2014, 08:40 PM Thread Starter
laybackman
laybackman's Avatar
2010 JK Wrangler
I used it the way it came out of the can. The finish on the top was not shiny or too smooth. All I did was clean it, rinse it and paint it using a small sponge brush for the edges and a 4" finish foam roller that they use for cabinets finishing. Came out well and looks just as nice a now.
post #112 of 116 Old 06-24-2014, 05:55 PM
ronkent
I gotta say im impressed. I have a 95 wrangler and wanted some ideas, saw this thread and was like 'what the hell?' I definitely did not expect to see what I saw in those pictures. well done!
ronkent is offline
post #113 of 116 Old 06-24-2014, 07:23 PM Thread Starter
laybackman
laybackman's Avatar
2010 JK Wrangler
I am just one more person in along line of people who decided to paint their vehicle in this manner. There is no way one can get as good a paint job for such little money/time/expertise (I had NONE!).
I have received a bunch of comments on it and when I tell them how I painted it they can't believe it.
I will need to address some rust just starting to come through where the flair extensions and step were. I also have the typical small area of rust starting to show under the taillights at the bottom of the body area. I didn't touch under/behind any body panels initially. I figured that I'll get back to it soon.......which I have not done yet...
The hard top was in good shape but a bit faded. One coat of Rustoleum and it looks new.
There are other brands of paint that are as good if not better, that may offer more color choices. Needless to say preparation is the key. The painting part is the easiest part.
Some people have taken this method to the nth degree and boy does it show! More thin coats = a better finish. I did 'cheat' a bit during the thinning process and my YJ looks just fine to me.
Go for it!
post #114 of 116 Old 02-01-2017, 10:25 AM
Ricsan
Very nice results...congrats on the outcome of this Jeep.
Ricsan is offline
post #115 of 116 Old 03-08-2017, 09:01 PM
clarkg
1976 CJ5
This looks great. Glad i found this thread- i may have to try on my 76 cj5.
Your jeep logos on the side look great in the photo. How did you paint them without leaving masking tape lines? Just curious cause i know i will be picky about mine.
clarkg is offline
post #116 of 116 Old 03-09-2017, 05:50 AM Thread Starter
laybackman
laybackman's Avatar
2010 JK Wrangler
I didn't I did them freehand!!! Naw that's BS
I bought the jeep letters and the Sahara logo on eBay.
budget paint , roll on , roll on paint job , rustoleum
