Mounting Corner Armor to minimize corrosion - JeepForum.com
post #1 of 3 Old 10-22-2009, 12:38 PM Thread Starter
scs2016
Hi Folks,
I've recently started down the road of adding some rear corner armor (short Rokmen armor) and replacing the rear hinges on my TJ (2004). I'm replacing the hinges with Kentrol stainless (powdercoated black) because of corrosion issues with my originals.
In mounting my corner armor, I want to really think ahead, and protect my tub as much as possible from future corrosion issues. After drilling, I want to line the mounting holes/hole-eges with bedliner or primer paint to protect any exposed metal...
Would I be better off using a sealer (e.g., silicone) to seal the corners to the tub, or using dots of something to preserve a very small void space between the tub and the armor?
My thinking with trying to seal the armor to the tub is to protect from intrusion by salt spray (new england winters), mud, etc.
while the void space plan, would have the benefit of air circulation and perhaps even be a bit washable.
Any thoughts or advice would be much appreciated.
scs2016 is offline
post #2 of 3 Old 10-23-2009, 12:54 AM
Low98Dime
You could sand the area on the tub that the armor is going to be on and the backside of the armor its self down to bare metal and use something like zero-rust, it will seal everything up so water and oxygen can't penetrate the metal, no more worries about rust. I've used this stuff on my truck frame and the rockers of three cars that were in bad shape and after about 3 winters, no rust still. You can topcoat it too with any other type of paint if you want to color match it with the color of your jeep.
Zero Rust Corrosion & Rust Control Paint
Low98Dime is offline
post #3 of 3 Old 10-24-2009, 12:24 PM Thread Starter
scs2016
Thanks --
just out of curiosity, has anyone removed corner armor after a while? What did it look like under there?
scs2016 is offline
Clear corner lenses 03JeepTJ Paint and Body 1 02-10-2010 02:09 PM
painting behind corner guards WILLTAKE Paint and Body 6 01-18-2010 10:10 PM
Corner Guard problem Carolinatj906 Paint and Body 1 12-16-2009 08:58 AM
corner gaurds bigpapa18205 Paint and Body 0 11-01-2009 10:45 AM
