Monstaliner Prep - JeepForum.com
post #1 of 10 Old 06-10-2013, 07:29 PM Thread Starter
ayycharlay92
Monstaliner Prep
so ive been looking at monstaliner to do the exterior of my wj with, i got into an accident and my new doors are blue and the rest is like the tannish gold. my paint is all scratched up and instead of painting again im just gonna monstaline the whole thing.
so i have figured 3 gallons will cover the whole thing, but i had a few questions,
do i need to prime it first ? or will i be alright just sanding down my paint,
also would it be more recommended to get a spray gun or use the rollers when i do it? i wanna order the stuff soon just dont wanna get to much stuff i wont actaully need or get to little and be screwed
ayycharlay92 is offline
post #2 of 10 Old 06-11-2013, 07:42 PM
ATVRACER76
I believe they want you to use some sort of base primer or sealer before you put the monstaliner on.. Of course, you will have to sand and scuff the exterior to prep for the sealer or primer.. Magnetman would be able to tell you what needs to be used.. I would recomend spraying the liner over rolling it on.. I rolled on that stuff in my interior of my xj and that took quite awhile to do so i couldnt imagine rolling the exterior.. But im sure it could be done either way..
ATVRACER76 is offline
post #3 of 10 Old 06-18-2013, 03:18 PM
lunchbox704
I used a product like monstaliner and I didn't have to prime. I just sanded, wiped it clean, and rolled it on.
lunchbox704 is offline
post #4 of 10 Old 06-18-2013, 08:35 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
95% of Monstaliner jobs do not use primer. Priming is only recommended when someone has problems with existing paint job... peeling clear coat, cracking/checked paint, etc. or bare metal.
Good scuffing and solvent cleaning is all that's normally needed over original paint
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #5 of 10 Old 06-19-2013, 05:52 AM Thread Starter
ayycharlay92
When i talked to you recently you said that I should primer because I have 2 different color paints on my jeep
post #6 of 10 Old 06-19-2013, 08:29 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
That's a reason I left out. Choice of color and coverage is a factor also in your case
Other reason to prime is with some yellows and Predator because of coverage. White primer is recommended here
Connect with us on:
post #7 of 10 Old 06-19-2013, 09:13 AM
DNFJ
I rolled it on and it looks fine. Roll vs. spray makes a minimal difference in texture.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #8 of 10 Old 06-19-2013, 02:17 PM Thread Starter
ayycharlay92
I was thinking a cheaper route would be to paint my doors that are a differnt color the same color as my jeep, than when I do monstaliner the whole jeep I won't have to prime it.
The color of y jeep is gold and I got the desert sand monstaliner. So it shouldn't have an issue with the color showing up under the monstaliner
post #9 of 10 Old 06-19-2013, 02:29 PM
DNFJ
Dude it's like 50 bucks for like 8 cans of primer. More than enough to cover your heep.
Previous:
DNFJ is offline
post #10 of 10 Old 06-20-2013, 10:25 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You could prime only the doors in a light gray and you'll be fine. Get 2 spray cans of rustoleum automotive primer
Even if you wanted to prime the whole rig, 1 quart of our universal primer is enough and only costs $18 and you could roll the whole body with that
Connect with us on:
