Monstaliner and painting a CJ7 Hardtop - JeepForum.com
post #1 of 26 Old 02-28-2012, 06:15 AM Thread Starter
JKB63
2010 JK Wrangler
I just recently painted by 1985 CJ7 hardtop with the Monstaliner product. I used 1 gallon and 1 quart to do the exterior and interior. The top was a very dingy and beat up white and now it is a very new looking top in black. I am very happy with the product although I could have done a better job especially on the interior. See pictures attached and I hope this helps someone that is thinking about doing the same thing with the Monstaliner product!
JKB63 is offline
post #2 of 26 Old 02-28-2012, 07:18 AM
wildcatxj
1989 XJ Cherokee
looks great!
89 2door xj, 4.0, aw4, d30 locked w/posi-lock cable, 8.25 open, front tube bumper w/mile marker sec8000, hella 550's, roof rack, bunch of ironman Andy junk, dirtbound Mojave rear bumper, open system 2-core rad,
wildcatxj is offline
post #3 of 26 Old 02-28-2012, 07:22 AM
CrawlingForward
Nice work! I've considered doing the same for mine. If only I wasn't so indecisive on the eventual color scheme!
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #4 of 26 Old 02-28-2012, 08:14 AM
Jim1611
Jim1611's Avatar
The top sure came out nice! Thanks for showing the pictures.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #5 of 26 Old 02-29-2012, 05:39 AM
qlfarm
Looks great!
I am planning on doing my interior and exterior with Monstaliner as soon as the weather cooperates.
qlfarm is offline
post #6 of 26 Old 02-29-2012, 06:13 AM Thread Starter
JKB63
2010 JK Wrangler
Thanks guys. I also has to wait on the weather. I did my prep work and then had to wait a couple of weeks for the weather to cooperate. When I did my top (inside the garage) it was about 70 degrees outside and drying time was about 2 hours.
JKB63 is offline
post #7 of 26 Old 03-01-2012, 12:28 AM
karlo
Looks great. I'm planning to paint my hard top. Thanks for the idea.
karlo is offline
post #8 of 26 Old 03-01-2012, 10:33 AM
steelhead9
Repairs before application?
Did you have to make any repairs to your top before application? My top has a lot of little chips around the bottom and I was wondering whether I should put a fiberglass reinforcing band around the bottom before coating. Also I assume you took the glass out before coating? Any problem with the seals leaking because of the rougher coating? Any information about the application and tips would be appreciated. Thanks!
steelhead9 is offline
post #9 of 26 Old 03-01-2012, 11:09 AM Thread Starter
JKB63
2010 JK Wrangler
I did not remove the windows. I taped off the gaskets and windows. I had some chips and dings that I elected to not patch and because of the rough texture of the product once installed, it covered most if not all the imperfections. If you are good with working with fiberglass and want to make sure the edge looks new then i recommend going that route. Otherwise the product will cover most of the smaller dings.
JKB63 is offline
post #10 of 26 Old 03-01-2012, 05:31 PM
JoeSuff
1983 CJ7
I'd be curious to know how much heavier is the top or is it unnoticeable?
JoeSuff is offline
post #11 of 26 Old 03-01-2012, 06:44 PM Thread Starter
JKB63
2010 JK Wrangler
I didn't see any noticeable difference in the weight.
JKB63 is offline
post #12 of 26 Old 03-08-2012, 10:38 PM
Polecat
Polecat's Avatar
Excellent work! I have lined my tub with Monsta and have considered doing the hard top with it. I've even toyed with the idea of painting the entire jeep with it.
Polecat is offline
post #13 of 26 Old 03-09-2012, 01:51 PM Thread Starter
JKB63
2010 JK Wrangler
Thanks and yes, after I got finished the thought crossed my mind to do the whole Jeep. I haven't made that decision but if you do please post pictures. That might get me over the hump.
JKB63 is offline
post #14 of 26 Old 03-11-2012, 09:11 AM
rjbruzan
Is it quieter inside while driving?
Ron
rjbruzan is offline
post #15 of 26 Old 03-11-2012, 09:19 AM Thread Starter
JKB63
2010 JK Wrangler
I can't say I notice much difference. I did not use the hard top much before lining with Monstaliner. It was ugly to say the least.
JKB63 is offline
Primer for Monstaliner ZeroGravity Paint and Body 5 05-30-2017 03:57 PM
painting fiberglass hardtop - prep question Builder77sDad Paint and Body 5 06-19-2012 11:38 AM
Monstaliner Question gbbryant21 Paint and Body 17 02-05-2012 09:34 PM
Raptorliner VS Monstaliner VS etc mark12010 Paint and Body 26 05-04-2011 08:10 AM
Monstaliner Install on my YJ biasdesign Paint and Body 12 07-20-2010 08:42 PM
