I need a paint code please - JeepForum.com
post #1 of 11 Old 04-05-2010, 08:12 PM Thread Starter
shub_31
2007 XK Commander
Hey everyone,
New here. Just bought my wife a 2007 commander and I needed the paint code number. Yes I know its on the drivers door, but some moron ripped the tag off. I do know that it is Pewter. Walmart has pewter, but I need the code to make sure. thanks
shub_31 is offline
post #2 of 11 Old 04-07-2010, 01:05 AM
CopperCJ7
Start here...
Auto Color Library - The World's Largest Online Color-Chip Library
If all else fails, try your local Jeep stealership for help
Guns don't kill people... Bad trail spotters do.
What CJ owner doesn't want to hack up his harness for the next owner to have fun with?
Originally Posted by Broseph View Post
The thread will derail quicker than a walrus on a Crisco-soaked Slip 'n' Slide.
CopperCJ7 is offline
post #3 of 11 Old 04-07-2010, 01:09 AM
LuckRider
LuckRider's Avatar
Why would they pull the tag? That sounds like a sketchy part. Did you have a carfax done when you got it?
Anyways.... Good luck finding a matching color
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #4 of 11 Old 04-08-2010, 10:25 PM
soul_Less
1994 ZJ
run the VIN at the dealer.
and it does seem sketchy theres no sticker...
soul_Less is offline
post #5 of 11 Old 04-09-2010, 06:27 PM Thread Starter
shub_31
2007 XK Commander
this is what i found out. The jeep was in a front end accident after 6months of ownership. 2007 bought in feb of 2008. Paper work claims light pewter metalic. However, research shows that that color was discontinued in 2004. How could they repaint a car with that color.
shub_31 is offline
post #6 of 11 Old 04-09-2010, 07:15 PM
soul_Less
1994 ZJ
you can get good paint shops to mix you up the specific color of your vehicle by mixin different paints together, probably how they did it..
post #7 of 11 Old 04-09-2010, 08:19 PM
LuckRider
LuckRider's Avatar
Yep, they can either mix it up, or found an old can. Just because it was discontinued doesn't mean it still doesn't exist.
Support Our Troops!
JFI Member #7:
post #8 of 11 Old 04-11-2010, 08:56 AM
Mahendra
Hallo guys,
Does anyone can help me for painting color 99 Forest green/PG8 color for TJ: I need information the PG8 Paint Merk? is it Danaglos?
I am planning to repainting my jeep
Please help!
Thanks
Mahendra is offline
post #9 of 11 Old 04-11-2010, 09:29 PM
LuckRider
LuckRider's Avatar
Just look for the paint using the color code. It is on the inside of the driver's side door jamb. It should be listed by code, not name.
(By the way, Welcome to the forum. The translator can make it harder to understand some times).
Support Our Troops!
JFI Member #7:
post #10 of 11 Old 04-16-2010, 05:56 AM
sideways
You can always pull the fuel door off and take it to a paint jobber.
They can scan the door, which will give them the mixing formula.
They also have chip books that go by year and make which will give you the paint code.
sideways is offline
post #11 of 11 Old 04-16-2010, 02:57 PM Thread Starter
shub_31
2007 XK Commander
i found the color
I called the origianl seller with the vin and the color is light greystone pearl. thanks everyone for your help
shub_31 is offline
What paint? Kheeney5 Paint and Body 2 02-26-2010 04:47 PM
Need some paint help. LURCH634 Paint and Body 1 02-19-2010 05:02 PM
Can you paint this? DirtyJeepBoy Paint and Body 3 01-12-2010 10:43 AM
Paint colour/code identification Jonnylandagent Paint and Body 3 11-22-2009 07:23 AM
How much to Paint TJ? hoytpotater Paint and Body 3 11-11-2009 08:20 PM
