How hard is it to spray single stage metallic paint really - JeepForum.com
post #1 of 8 Old 03-24-2011, 01:44 PM Thread Starter
Capt_Drake
I like my charcoal grey metallic (code 4m) and I'm thinking that this will match close enough
http://www.tcpglobal.com/restorationshop/rsp2104.aspx
because I don't want to spend large amounts (>$400) for exact match. Also, I will be wheeling this thing and honestly, a show level paint job seems ridiculous.
So my question is, how hard is it, really, to spray a SINGLE STAGE URETHANE and get it somewhat descent?
Capt_Drake is offline
post #2 of 8 Old 03-25-2011, 12:20 AM Thread Starter
Capt_Drake
come on, anyone?
post #3 of 8 Old 03-25-2011, 05:22 AM
WarInc
In my experience with single stage paint I have learned one thing, it is more temperamental then my wife. Single stage if done correctly can be laid very smooth and nice but you will find there is a very small margin for error. Watching many new people spray single stage you find typically they try to spray lighter then what is wanted which leads to a dry non-smooth coat. Then they go back over and try to over compensate which leads to major runs. Either way isn't to important as long as you have a few good coats the paint can be wet sanded and buffed.
2001 WJ Mall Crawler Build
WarInc is offline
post #4 of 8 Old 03-25-2011, 03:13 PM Thread Starter
Capt_Drake
Thanks^^^
I'll practice a bit before I shoot the body, and you're saying go a LIIIttle bit towards the heavy side of light.
post #5 of 8 Old 03-25-2011, 07:01 PM
Ironworker709
Ironworker709's Avatar
Sanding and buffing a single stage metallic is VERY hard to do without getting blotches that are different shades and metallic streaks..
When spraying a metallic single stage you want to spray it "just wet"..no more..no less,and the gun needs to be set differently to every brand and type and quality of paints,some are less pigmented..someare thicker..thinner..shades different..more or less metallic..etc etc.
If you never painted a full vehicle before,get an extra quart or so and pratice the settings and technique of the gun before going onto the vehicle and painting..
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #6 of 8 Old 04-05-2011, 06:32 PM
243
1978 FSJ Cherokee
I used TCP Global Silver Firemist on engine, trans and xfer case and it turned out great. It was all sprayed with the purple hvlp HF gun and I was very happy with the paint. The only issue I had was I sprayed a little heavy on the drivers side of the motor and I have a little metallic shift.
On the other hand, I used Nason single stage on my daughter's truck and it had a lot of orange peel. This may have been due to using the incorrect reducer for the temperature in the booth.
Dave's 78 Build
243 is offline
post #7 of 8 Old 04-06-2011, 09:06 PM
JHW12084
1990 XJ Cherokee
it sounds stupid, and totally defeats the purpose....but stick a coat of clear over the entire job. therefore, when colorsanding, you wont get blotches....however if the paint is put on properly, without runs there wont be any mismatches in color. but i think it would ber smarter for base clear
JHW12084 is offline
post #8 of 8 Old 04-26-2011, 08:36 AM
Ironworker709
There is ALOT of painters using the single stage urethane under a urethane clear coat now instead of the flat base coat,just have to stay within the window of the re-coat and make sure it is compatible.
It gets a much deeper shine in end result
Regular base coat is much "easier" because it dries so quick so therefore much easier and quicker for production so it makes an easier product for the amatuer for the fact as long as the base coat is sprayed nice,you can spray a clear coat over it and even if you somewhat screw up the clear coat it is really easy to fix without re-spray as compared to a single stage with no clear.
But here we get back to spraying a single stage without screwing it up before the clear coat is applied over it
Never forget 9/11
single step paint b-dog Paint and Body 6 02-13-2011 07:24 AM
issue with rustoleum auto primer and napa crossfire single stage? Chuckles0227 Paint and Body 1 07-23-2010 12:16 PM
best spray can paint to use? postaldave Paint and Body 11 05-02-2010 12:32 AM
Best spray can paint LST022752 Paint and Body 12 03-23-2010 12:41 AM
Single stage or base coat? What's the difference? grnjp88 Paint and Body 5 01-13-2010 03:54 PM
