-   Paint and Body (http://www.jeepforum.com/forum/f260/)
-   -   How to clean/remove this? (rust and some other stain) (http://www.jeepforum.com/forum/f260/how-clean-remove-rust-some-other-stain-1531967/)
cucr3 06-03-2013 06:23 PM
Any recommendations or tips on how to get the rust off of my TJ and some run-off, off of my back window? I tried CLR, bleach and various other cleaners. Thanks
http://i1075.photobucket.com/albums/...ps6e4c2b87.jpg
http://i1075.photobucket.com/albums/...psb5d10899.jpg
rjbruzan 06-03-2013 07:33 PM
The rust may have etched the glass . The body will cleanup with rubbing compound on a rag or with a buffer/polisher. Take it easy doing it to prevent more damage. Was there some kind of rack on the roof?
cucr3 06-03-2013 08:01 PM
Ok cool, thanks. I'm not too sure, I just picked the jeep up and want to take care of all these little cosmetic issues right away. Any brand recommendations for the rust rubbing compound?
athos76 06-04-2013 02:01 AM
Just rubbing compound. Not rust rubbing compound. Turtle wax makes a cheap one.
goldhammer 06-04-2013 01:33 PM
Try some 4/0 steel wool on the glass. Usually that will clean that kind of stuff off if it has not eaten into it.
Try to stay right on the bad spots with the compound, or you can cut through the paint on each side before the heavy stuff is gone. Probably not going to get it all.
Ironworker709 06-04-2013 04:07 PM
For the glass BEFORE you try any kind of abrasive material....use Laquer Thinner...be carefull not to get any on any painted area..it can eat paint...
If the laquer thinner doesn't work,it's etched into the glass,buy an automotive glass polishing kit,they can rid fine scratches in auto glass and polish it like new.
If you use anything even the slightest abrasive on glass,it'll need polished
A good rubbing compound should work on the paint,after its gone,use a polish to renew the clear coat shine.
I've also had some good luck with Goof Off stain remover for rust stains on paint
cucr3 06-04-2013 04:48 PM
Thanks everyone. I bought some turtle wax rubbing compound and will see how it works. I am selling the hardtop, so maybe I'll just leave the glass and let the new owner deal with it. Give him a little discount or something.
goldhammer 06-04-2013 05:47 PM
4/0 fine steel wool will not scratch glass (will eat plastic though). Body shops use it all the time to remove overspray from glass. Works well for the pesky baked on bugs before you Rain-X it for winter as well just use soapy water of glass cleaner.
The time now is 12:09 PM.
