Herculiner on plastic side skirt - JeepForum.com
post #1 of 8 Old 05-16-2010, 11:54 AM Thread Starter
garrardao
Hi i've got a 2000 grand cherokee laredo and my side skirts are faded. I've used mother's back to black and it looks really good when its applied but the problem is that it fades really fast! So i've been thinking about using rhino liner or herculiner on the side skirts for a more permanent fix. But i've never used it before and im not sure if it will stick to plastic and if i would need to sand the side skirts so it will stick better. Any help would be greatly appreciated! Thanks!
garrardao is offline
post #2 of 8 Old 05-17-2010, 03:42 AM
CopperCJ7
I would suggest using Durabak instead. That stuff is made for exterior applications and has UV built right in. Herculiner will fade to gray also unless you mix in their UV coating. I'm fairly sure that if you scuff up the plastic and prime it, it'll stick to it. I would confirm that with the product's manufacturer before you buy.
Guns don't kill people... Bad trail spotters do.
What CJ owner doesn't want to hack up his harness for the next owner to have fun with?
Originally Posted by Broseph View Post
The thread will derail quicker than a walrus on a Crisco-soaked Slip 'n' Slide.
CopperCJ7 is offline
post #3 of 8 Old 05-17-2010, 09:52 AM Thread Starter
garrardao
Cool yeah i'll definitely look into that and check with them to make sure that it will work. I've never seen it in stores though, where can i get some Durabak? Do you have any recommendations for the primer that i should use or does it really not matter which one?
post #4 of 8 Old 05-17-2010, 06:25 PM
CopperCJ7
Here's a link to page one of TWO pages of links about coatings
http://www.jeepriver.com/links/index...09030217401482
Good luck
post #5 of 8 Old 05-17-2010, 06:36 PM
jeep4alex
I use boiled linseed oil from home depot on my LJ factory fender flares.
On wipe on treatment is good for several months. Brings the look back to new!
Only drawback is the odor is strong for 24 hrs.
jeep4alex is offline
post #6 of 8 Old 05-17-2010, 08:12 PM
footinmouth47
footinmouth47's Avatar
for most grand owners myself included krylon fusion is the best product to get your cladding black and have it stay that way. it is also smooth unlike bed liner and really easy to use very little prep needed. I did mine over 3 years ago and it still looks great only a few light spots where car doors and branches have really hit hard. I have seen that it now comes in a wide verity of colors even hammered finish. here is a pic at about 2 yearsafter paint, I used black Im sure you can find lots of threads if you do a search for it.
Greg
98 zj (The Vixen) 5.2 V8, 4 in f>r, 31's,
Built not Bought member #247
SOLD:( new DD- 04 polaris sportsman
footinmouth47 is offline
post #7 of 8 Old 05-17-2010, 08:43 PM
CopperCJ7
Some companies make bed liner or coatings that are fairly smooth and some that are rough - some make both.
post #8 of 8 Old 05-17-2010, 10:29 PM Thread Starter
garrardao
You guys are seriously awesome! Thank you so much for all of your help! I'll definitely check out those websites and look into the krylon paint too. I'm still going back and forth on what i will end up doing but i should be getting it done pretty soon and i will put up pictures to show you all how it turned out!
herculiner , paint , side skirt
Removing Herculiner GroundAssault Paint and Body 15 05-24-2010 10:37 PM
How to reglue those plastic out side my jeep ? NeverL8 Paint and Body 2 01-25-2010 01:05 PM
Where to get Herculiner? PrJeep Paint and Body 10 01-02-2010 12:28 PM
another herculiner 88YJoe Paint and Body 3 10-27-2009 11:09 PM
