Frame paint - JeepForum.com
post #1 of 5 Old 04-11-2010, 04:37 PM Thread Starter
BobA
Frame paint
I want to paint my frame areas and underneath just to clean things up. I've used regular black spraypaints in the past and it looks like its been rattlecanned. Do they make a black spraypaint that looks more like the quality "factory" paint?
01 TJ Sahara
6cyl. 5spd, D30 Aussie/D44 LSD,4.56 gears, RC2.5" lift, RC1.25" body lift, 33's
77 DJ5
Soon to be streetrod
BobA is offline
post #2 of 5 Old 04-11-2010, 04:44 PM
USAFRecon
POR 15 FTW.
http://www.por15.com/
USAFRecon is offline
post #3 of 5 Old 04-11-2010, 05:57 PM
57plymouth
Get a $18 paint gun from Harbor Freight and paint it with $35 black paint from your local Caterpillar or John Deer dealer. It will look great and last forever.
Virtus Junxit Mors Non Separabit
57plymouth is offline
post #4 of 5 Old 04-13-2010, 07:06 AM Thread Starter
BobA
Ok, Thanks
01 TJ Sahara
77 DJ5
BobA is offline
post #5 of 5 Old 04-16-2010, 06:31 PM
Low98Dime
I've heard and seen bad things about por-15. It tends to flake off or scratch easily for some, even if they prep'd the metal properly. Look into a product called ZeroRust, I've used it and it is tough as nails, looks factory, and will keep anything from rusting. It comes in spray cans, and quarts/gallons, if you get it in a quart or gallon, you can thin it down with paint thinnner so you can spray it if you just want to get a cheap paint gun. (comes with instructions on how to do it).
Zero Rust Corrosion & Rust Control Paint
Low98Dime is offline
extreme frame rust timinfla2 Paint and Body 7 07-29-2010 10:03 AM
What paint? Kheeney5 Paint and Body 2 02-26-2010 04:47 PM
holes in the windshild frame. how to fix? lancer27 Paint and Body 6 02-02-2010 06:30 PM
So I have a quart and a half of Por-15 is this going to be enough for the frame & tub Goobersbro Paint and Body 3 01-04-2010 03:51 PM
How much to Paint TJ? hoytpotater Paint and Body 3 11-11-2009 08:20 PM
