fixing bubbled clear coat - Page 2 - JeepForum.com
post #16 of 16 Old 10-05-2009, 07:06 PM
Ironworker709
Ironworker709's Avatar
Originally Posted by BULLITTBUilder View Post
Yeah but you might want to check that again. The 90 PSI is at the compressor not at the cap, at the line you drop it to 30 psi and there is an internal regulator in the gun that drops it down to around 10 psi. If you set the compressor to 30 psi you would barely be spraying paint, if you were even able to atomize the paint it would look orange peeled and rough as hell. There are at least 3 regulators in a paint system, and all 3 are required regardless of what gun you have. THere is one at the compressor, one AT the gun and there is the one inside the gun. All three are adjustable and the first 2 should always be filtered.
The one inside the gun is a PAINT filter,not AIR.I know SOME guns come with an air filter inside the gun,but anyone i know removes them because it will mess with the air flow too much and collect water/dirt inside the gun itself,thats why the filter is put AT the gun externaly for the air.
30 PSI in the line is more than efficeint enough to run an HVLP and several other people i know who paint daily,as a matter of fact when i started painting myself again 8 years ago,i had to get advice from pro's i know because i was used to the 70's/80's single stage paint and old guns and all who i asked only run 30 PSI in the line at most because of possible damage to a good gun.
Painting with plastic as a temporary booth is always a no no in my book,the plastic will wave in the moving air needed for ventilation and removal of overspray,..and overspray landing on plastic will also fall off the plastic while spraying and landing on the paint job,ask me how i know.....
As far as the concern for temperature while spraying,they have different reducers for different temps.Slow,Medium and Fast.
As far as a good budget paint line,i like Omni,good quality,nice spraying for a good price,I recently painted a ford ranger for a freind's son's first vehicle with Omni VW Regatta Metallic blue BC/CC and came out beautiful,only paid 90.00 for the gallon and mix ratio is 50/50,so you get 2 gallons out of it.
But everyone has their own opinions/preferences in paint lines,,being budget or top of the line.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
Clear corner lenses 03JeepTJ Paint and Body 1 02-10-2010 02:09 PM
Clear Powdercoat? BeerMe Paint and Body 3 01-23-2010 10:04 AM
clear coat peeling...? fishmanwill Paint and Body 3 01-14-2010 12:38 PM
Single stage or base coat? What's the difference? grnjp88 Paint and Body 5 01-13-2010 02:54 PM
Proper way to repair a rust spot w/ paint and clear... ISUzj Paint and Body 9 11-11-2009 08:03 AM
