First time painting - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Paint and Body > First time painting
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsDisc Brake Kits from ECGS
Unread 07-21-2014, 09:05 PM   #1
mallard3914
1978 CJ7
First time painting
Can someone explain this statement:
When sealing, final sand repair area with 320400 grit sandpaper. If directly top coating over primer, final
sand with 400600 grit sandpaper.
mallard3914 is offline   Reply With Quote
Unread 07-21-2014, 10:48 PM   #2
Ironworker709
Ironworker709's Avatar
The term sealer just means if you are using a sealer primer,such as an epoxy primer that can be generaly reduced to 20% to make it a sealer
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...http://www.ironworkers.org/becoming/careers.aspx
Ironworker709 is online now   Reply With Quote
Unread 07-22-2014, 08:06 AM   #3
swirve
What iron worker said. You can use epoxy or urethane sealer. Basically it fills the 600 scratches and covers up any cut throughs you may have providing a uniform surface for your top coat
swirve is online now   Reply With Quote
Unread 07-22-2014, 08:23 AM   #4
swirve
Also if you have any bare metal spots larger than a silver dollar you should use an epoxy sealer vs. Urethane
Unread 07-22-2014, 09:07 AM   #5
mallard3914
1978 CJ7
thanks guys
