Eastwood frame rail paint. How did you do it? - JeepForum.com
post #1 of 7 Old 06-13-2013, 01:47 PM Thread Starter
TJJeepJosh
I bought some of the internal frame rail paint from eastwood and wondering what would be best to do before applying it.
http://www.eastwood.com/internal-fra...ay-nozzle.html
But I also bought this rust converter from them.
http://www.eastwood.com/ew-rust-conv...a-aerosol.html
Would it be best to just wash down inside the frame and spray with the frame rail paint.
Wash down inside and first spray with the rust converter then the frame rail paint.
Since it states on the frame rail can that "phenolic resin penetrates, converts and encapsulates the rust on the internal surface, and zinc phosphate seals it." I wonder if using the rust converter would defeat the purpose of it or if it would actually help.
opinions?
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline
post #2 of 7 Old 06-14-2013, 07:36 AM
Jims-87YJ
1987 YJ Wrangler
When I did mine I stripped the frame, pressure washed then sandblasted. I got as much sand out of the inside of the frame as I could using a long air hose. I then use the internal frame spray from Eastwood and let dry, Then used the Chassis Saver from Magnet Paints on the exterior, followed by Eastwood Extreme Chassis Black as the UV blocker. I am very happy with how it turned out. I did not have to use the rust converter after blasting so I can not comment on that.
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #3 of 7 Old 06-14-2013, 01:28 PM
Renegade82
1982 CJ7
Put the internal frame paint right on the frame. After it's well dried of course. No need to topcoat that. It's made to go on the rust and it's a very runny paint so it will seep into the nooks and crannies. I used it on mine but it was a new bare metal TDK frame. I laid it on the topside and used one can to do both rails. Left it set till the next night, flipped it onto it's bottomside, and did the same thing again. That way it will puddle on the top and bottom and cover those areas with a good coating. Tape any holes in the frame to keep the spray inside (and the mess), and just peal back the tape as needed for access of the hose.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #4 of 7 Old 06-14-2013, 01:47 PM Thread Starter
TJJeepJosh
I probably will be spraying mine within the next few days. Already did the exterior with chassis saver with just a rustoleum flat black top coat. Didnt even think of inside the frame rails until I looked online at others and inside my rails to see the rust. Looks like it goes straight on. Thanks for the help
post #5 of 7 Old 06-14-2013, 02:11 PM
Renegade82
1982 CJ7
Keep some rags handy to wipe off your outside paint, and wear some gloves. It's great stuff but I've used about 5 cans of the stuff now and every one leaked around the can to sprayer connection. It puddles around the top then when you tilt the can it pours out.
post #6 of 7 Old 06-14-2013, 06:59 PM Thread Starter
TJJeepJosh
Interesting. Thanks for the heads up. Bet I'll still get it all over myself. Even with gloves and other protection I always somehow manage to get myself covered in paint.
post #7 of 7 Old 06-16-2013, 09:19 PM
Copperhead89
I used the Internal Frame stuff on the inside of my sandblasted frame. It stinks, so make sure you have good ventilation. But to me, that stink tells me its good stuff! I agree with the rubber gloves recommendation.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline
