-   Paint and Body (http://www.jeepforum.com/forum/f260/)
-   -   Eastwood frame rail paint. How did you do it? (http://www.jeepforum.com/forum/f260/eastwood-frame-rail-paint-how-did-you-do-1536049/)
TJJeepJosh 06-13-2013 12:47 PM
I bought some of the internal frame rail paint from eastwood and wondering what would be best to do before applying it.
http://www.eastwood.com/internal-fra...ay-nozzle.html
But I also bought this rust converter from them.
http://www.eastwood.com/ew-rust-conv...a-aerosol.html
Would it be best to just wash down inside the frame and spray with the frame rail paint.
Wash down inside and first spray with the rust converter then the frame rail paint.
Since it states on the frame rail can that "phenolic resin penetrates, converts and encapsulates the rust on the internal surface, and zinc phosphate seals it." I wonder if using the rust converter would defeat the purpose of it or if it would actually help.
opinions?
Jims-87YJ 06-14-2013 06:36 AM
When I did mine I stripped the frame, pressure washed then sandblasted. I got as much sand out of the inside of the frame as I could using a long air hose. I then use the internal frame spray from Eastwood and let dry, Then used the Chassis Saver from Magnet Paints on the exterior, followed by Eastwood Extreme Chassis Black as the UV blocker. I am very happy with how it turned out. I did not have to use the rust converter after blasting so I can not comment on that.
Renegade82 06-14-2013 12:28 PM
Put the internal frame paint right on the frame. After it's well dried of course. No need to topcoat that. It's made to go on the rust and it's a very runny paint so it will seep into the nooks and crannies. I used it on mine but it was a new bare metal TDK frame. I laid it on the topside and used one can to do both rails. Left it set till the next night, flipped it onto it's bottomside, and did the same thing again. That way it will puddle on the top and bottom and cover those areas with a good coating. Tape any holes in the frame to keep the spray inside (and the mess), and just peal back the tape as needed for access of the hose.
TJJeepJosh 06-14-2013 12:47 PM
I probably will be spraying mine within the next few days. Already did the exterior with chassis saver with just a rustoleum flat black top coat. Didnt even think of inside the frame rails until I looked online at others and inside my rails to see the rust. Looks like it goes straight on. Thanks for the help
Renegade82 06-14-2013 01:11 PM
Keep some rags handy to wipe off your outside paint, and wear some gloves. It's great stuff but I've used about 5 cans of the stuff now and every one leaked around the can to sprayer connection. It puddles around the top then when you tilt the can it pours out.
TJJeepJosh 06-14-2013 05:59 PM
Interesting. Thanks for the heads up. Bet I'll still get it all over myself. Even with gloves and other protection I always somehow manage to get myself covered in paint.:D
Copperhead89 06-16-2013 08:19 PM
I used the Internal Frame stuff on the inside of my sandblasted frame. It stinks, so make sure you have good ventilation. But to me, that stink tells me its good stuff! I agree with the rubber gloves recommendation.
The time now is 02:20 PM.
