Dynaglass vs. Ultraglass - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Paint and Body > Dynaglass vs. Ultraglass
Cess Recovery Gear Snatch Tow Strap OffRoad @ ROCKRIDGE4WDGEARSHADE Pocket Tops in stock and available at ROCKRIDGE Engo winches available at www.rockridge4wd.com! Free shipp
Unread 04-09-2014, 09:26 AM   #1
Renegade82
Renegade82's Avatar
1982 CJ7
Does any of you bodywork guys have any experience using 3M/Dynatron's Dynaglass or Ultraglass short strand fiberglass reinforced fillers? Looking at their website they claim one is waterproof (dyna) and one is water resistant (ultra). But yet when you do a "compare", the "performance level" says the ultra is better. I know it's a website that was created by some data input person who has probably never seen the inside of a body shop, so I don't put much stock in their descriptions.
Does anyone know the difference and do you prefer one over the other? And if you've used them, what finishing filler did you use over it?
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (still in progress....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote
Unread 04-09-2014, 06:00 PM   #2
swirve
Originally Posted by Renegade82
Does any of you bodywork guys have any experience using 3M/Dynatron's Dynaglass or Ultraglass short strand fiberglass reinforced fillers? Looking at their website they claim one is waterproof (dyna) and one is water resistant (ultra). But yet when you do a "compare", the "performance level" says the ultra is better. I know it's a website that was created by some data input person who has probably never seen the inside of a body shop, so I don't put much stock in their descriptions. Does anyone know the difference and do you prefer one over the other? And if you've used them, what finishing filler did you use over it?
First off what are you trying to accomplish? Are you covering up a buncha rust?
I prefer Upol Fiber all. It spreads thick or you can spread it real smooth. Sands nice also. Top it with Upol flyweight gold
swirve is offline   Reply With Quote
Unread 04-09-2014, 09:07 PM   #3
Renegade82
Renegade82's Avatar
1982 CJ7
No, just smoothing up irregular surfaces and covering some weld voids. No holes. It's all been covered with POR and TieCote.
Unread 04-09-2014, 09:30 PM   #4
swirve
Ok. Well I really prefer the Upol Fibral. For the heavy work. Plus it comes in squeeze tubes which is nice
Unread 04-29-2014, 12:16 PM   #5
kingcat400
Strip all the por off before you do filler or you will be sorry in a few months when all the filler is coming off. I know this from first hand experience.
I use us chemical duraglass and have never had any issues except for por coming off under it and having to start over.
kingcat400 is offline   Reply With Quote
Unread 05-01-2014, 10:17 AM   #6
Renegade82
Renegade82's Avatar
1982 CJ7
That would defeat the purpose of protecting the metal. You can put filler on over POR but you first have to put down either TieCoat or their self etching primer between them. Just as some shops spray epoxy on the bare metal before the filler.
Unread 05-01-2014, 06:08 PM   #7
kingcat400
The issue is the por will separate from the metal after a few months or even weeks. I speak from experience. I had it happen on a show car and a truck. Also duraglass is direct to metal.
Unread 05-01-2014, 06:31 PM   #8
swirve
Sticks way better to sanded and cleaned epoxy
Unread 05-01-2014, 06:45 PM   #9
kingcat400
When I had the rep for us chemical in my shop they recommended direct to metal for best adhesion. I was more concerned with him using it over por as I and many others have had issues with it coming off causing you to have to redo the whole area. If you wanted to use something under I recommend ppg dp90lf.
Unread 05-01-2014, 06:47 PM   #10
kingcat400
Could you please show manufacturer instructions that show to use over epoxy.
Unread 05-01-2014, 06:47 PM   #11
swirve
Try Ppg' CRE. X100 better than that LF crap and its direct to metal and has better film build
