DIY paint job! - JeepForum.com
post #1 of 10 Old 04-28-2013, 10:01 PM Thread Starter
skysub
DIY paint job!
I just bought my dream car (1992 wrangler) and it needs a new paint job but I don't want to pay the thousand to paint it. How do I do my own good quality paint job? What do I need?
skysub is offline
post #2 of 10 Old 04-28-2013, 10:29 PM
MikeHoncho88
2015 JK Wrangler
Google $50 paint job or $100 paint job. Lots of people use tractor paint and rollers or else buy a cheap harbor freight spray gun.
Or google plastidip. Lots of people use that as well.
There are usually shops that will shoot your car for a few hundred if you do the prep. Look into local shops and see what they will do or you.
MikeHoncho88 is offline
post #3 of 10 Old 04-29-2013, 06:33 AM Thread Starter
skysub
Alright thanks!!
skysub is offline
post #4 of 10 Old 04-29-2013, 06:43 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Depending on how cheap you want to do this, you're gonna need:
1. A box of GRAY Scotchbrite
2. A can of Wax & Grease remover.
3. A box of Scott's Blue Shop towels. Wipe down everything you scuff, then DON'T TOUCH.
4. Paint, use the Duplicolor rattle cans from an auto parts store. O'reilly's has it.
D3<!L!>3D
S8NNG8 is offline
post #5 of 10 Old 04-29-2013, 08:58 AM
ohiocj
A guy I met who painted his JD tractor told me about this. The piant job looked like it was still wet! To get a good finish out of a rattle can you fill a bowl with very hot tap water. Put rattle can in tap water and let it sit for 10 -15 mins. Once the paint is warmed, spray it on like you normally would. Then if you get real ambitious you can buff it out with compund and then wax it!
1985 CJ-7
1952 CJ3A
ohiocj is offline
post #6 of 10 Old 05-01-2013, 04:33 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Who needs paint when you can cover it all up with diamond plate It's got a shine, and who cares if it gets scratched.
D3<!L!>3D
S8NNG8 is offline
post #7 of 10 Old 05-01-2013, 04:36 PM
athos76
Just wanted to add: wear latex or nitrile gloves and change them often. Helps to eliminate the "did I just touch that?" feeling.
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #8 of 10 Old 05-01-2013, 04:39 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Good point. The oil on your skin is an adhesion killer.
D3<!L!>3D
S8NNG8 is offline
post #9 of 10 Old 05-01-2013, 04:55 PM Thread Starter
skysub
What grit should the scotchbrite be?
skysub is offline
post #10 of 10 Old 05-01-2013, 05:16 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
They are all guaged by color. GET GRAY.
D3<!L!>3D
S8NNG8 is offline
