'Desert Sand Pearl' in a single stage paint? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Paint and Body > 'Desert Sand Pearl' in a single stage paint?
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 07-10-2014, 05:02 PM   #1
citRon
The Cherokee is still in construction phase, but thinking ahead of paint. I'm 50/50 on a Monstaliner exterior or an inexpensive single stage paint.
Does anyone with knowledge/experience know if factory colors that are 2-stage (base and clear) can be made as a single stage paint? Specifically I'm interested in Desert Sand Pearl...
1996 Cherokee Country 4x4
citRon is offline   Reply With Quote
Unread 07-10-2014, 05:34 PM   #2
Jeephreakiwon
I don't know about professionally spraying a single stage but any pro paint shop should be able to put it in a spray can. You can paint with it as it is single stage in the can. I have painted approximately 99% of my Wrangler using it. In Desert Sand Pearl as well. Best thing to do is check with your local paint shop and see what they recommend depending on what you want to accomplish.
Jeephreakiwon
Jeephreakiwon is offline   Reply With Quote
Unread 07-10-2014, 06:14 PM   #3
citRon
cool- pics!! What i would do is have it mixed as a gallon and spray it with a cheap HF gun. I have a large enough compressor.
Unread 07-10-2014, 06:24 PM   #4
Jeephreakiwon
This is the best pic I could find as I'm on my phone. I don't know if they can do it in a gallon. I used around 7-10 cans and it turned out great.
Jeephreakiwon
Unread 07-10-2014, 06:37 PM   #5
citRon
that's a great picture!
Unread 07-10-2014, 07:16 PM   #6
swirve
Can be done but unless you've had a gun in your hands for many years i wouldnt recommend it.
swirve is offline   Reply With Quote
Unread 07-10-2014, 07:21 PM   #7
Jeephreakiwon
Thank You!! I just wish it didn't happen but at least nothing broke and no one was hurt.
Jeephreakiwon
Unread 07-15-2014, 02:53 AM   #8
Drednot
I've used the color/clear rattle cans and they turn out great. The desert sand is a cool color.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is offline   Reply With Quote
Unread 07-19-2014, 06:27 PM   #9
steelpikr
Its best done as a base coat / clear coat process. Its not harder than doing a one time process, just takes a little longer.
steelpikr is offline   Reply With Quote
