Correct way to paint this? - JeepForum.com
post #1 of 3 Old 09-15-2013, 05:03 PM Thread Starter
98tjsahara
I'm working on reviving a ford 8.8" rear axle assembly from its rusty junkyard grave and I have got the brake mounting brackets cleaned up using the electrolysis method. When I paint these brackets, can I paint the whole thing or do I need to leave the mounting surface bare metal? Do I need to reinstall them before painting and then paint the whole assembly at once? Also what is the best way to prep the metal before paint? I'll be using Rust-oleum primer/paint in a spray can, they recommend soap/water prep, is that sufficient? Thanks!
Before:
After:
Sold the 98 TJ Sahara. Buying another Jeep soon!
98tjsahara is offline
post #2 of 3 Old 09-16-2013, 07:54 AM
Ironworker709
Ironworker709's Avatar
Things like that i generaly never paint the mounting surfaces...
Just either grease or neverseize a VERY thin coat on the mounting surfaces carfefully not to get it on any other part of it,bolt it on the axle and paint away
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #3 of 3 Old 09-17-2013, 04:38 AM
ToledoDave
Ironworker is abolutely right. Having anything between two mating surfaces not originaly installed will jeopardize torque integrity on your bolts not to mention any offsets like shimming between parts. If I did paint over a surface I would definitely sand the surfaces back to metal before reinstalling.
ToledoDave is offline
