clear coat bubbling/peeling - JeepForum.com
post #1 of 5 Old 04-20-2010, 09:11 PM Thread Starter
officer_krupt
any ideas on how to fix a few small areas where my clear coat is peeling...the paint is good .......just the clear is peeling ...i was thinking about smoothing the edges of spots with steel wool ....real fine steel wool....then hitting it with some spray bomb clearcoat.....any 1 got any ideas or experience with this? also any ideas where to find some citron pearl touch up paint
officer_krupt is offline
post #2 of 5 Old 04-21-2010, 12:16 AM
BULLITTBUilder
Once the clear coat is faded, peeled or in any way separated from the basecoat it is time for a respray. you can't simply respray clear over the base. the best way to correct it is scuff up the affect area, mask off and color blend the "spot", of course re clear. From there it is sanding, compounding and glazing. As far as finding paint in any quantity go to your local jobber, mine is Albert Kemperle and they'll be able to find your paint. This is not a cheap or easy process if you have no auto body experience
BULLITTBUilder is offline
post #3 of 5 Old 04-21-2010, 04:49 AM
Demp
x2
I'd look into having the part/outer body resprayed, if its within budget. Usually if one spot is bubbling, more will be showing up before long.
Demp is offline
post #4 of 5 Old 04-22-2010, 03:01 AM
Finaltheorem47
1992 XJ Cherokee
Once the clear delaminates from the base coat, new base coat needs to be sprayed along with the clear.
Finaltheorem47 is offline
post #5 of 5 Old 01-19-2011, 10:14 PM Thread Starter
officer_krupt
yeah.... just keeps getting worse!!!!!!
Basic Powder Coat Question jclark50 Paint and Body 8 05-03-2010 10:25 AM
questions about taking my jeep from bare metal to clear coat? Goobersbro Paint and Body 6 04-12-2010 07:41 PM
clear coat peeling...? fishmanwill Paint and Body 3 01-14-2010 01:38 PM
Single stage or base coat? What's the difference? grnjp88 Paint and Body 5 01-13-2010 03:54 PM
fixing bubbled clear coat KJFactor Paint and Body 15 10-05-2009 08:06 PM
