Boken Bolts - JeepForum.com
post #1 of 4 Old 07-23-2013, 10:48 PM Thread Starter
HDPARTSDUDE
Boken Bolts
I'm a novice mechanic at best. I've got a bed liner project going on with my '01 TJ and I've broke off two bolts. After buying and destroying a bolt extractor kit from Autozone I'm wondering if I should have gone to Sears. Any suggestions?
HDPARTSDUDE is offline
post #2 of 4 Old 03-04-2015, 02:59 PM
wmg
oppps
I dont know how large (diameter) of a bolt you are trying to remove however when you use an extractor it pushes out on the bolt to get a good grip...and thus tightens up the bolt to hole....being carefull try drilling out larger in sucsession holes in the bolt, if its a fairly large dia you may be able once there is just a thin shell left to peel it away using a small chisel and light hammer taps...other option just drill out and re tap.
wmg is offline
post #3 of 4 Old 03-04-2015, 03:31 PM
ravenworks
ravenworks's Avatar
Left handed drill bit
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #4 of 4 Old 03-04-2015, 06:43 PM
swirve
Drill and re tap
swirve is offline
