-   Paint and Body (http://www.jeepforum.com/forum/f260/)
-   -   Boken Bolts (http://www.jeepforum.com/forum/f260/boken-bolts-1552919/)
HDPARTSDUDE 07-23-2013 09:48 PM
Boken Bolts
I'm a novice mechanic at best. I've got a bed liner project going on with my '01 TJ and I've broke off two bolts. After buying and destroying a bolt extractor kit from Autozone I'm wondering if I should have gone to Sears. Any suggestions?
wmg 03-04-2015 01:59 PM
oppps
I dont know how large (diameter) of a bolt you are trying to remove however when you use an extractor it pushes out on the bolt to get a good grip...and thus tightens up the bolt to hole....being carefull try drilling out larger in sucsession holes in the bolt, if its a fairly large dia you may be able once there is just a thin shell left to peel it away using a small chisel and light hammer taps...other option just drill out and re tap.
ravenworks 03-04-2015 02:31 PM
Left handed drill bit
swirve 03-04-2015 05:43 PM
Drill and re tap
The time now is 09:04 AM.
