Body Rust Repair - JeepForum.com
post #1 of 11 Old 05-27-2010, 12:54 PM Thread Starter
freeskier93
Body Rust Repair
So i've been doing some searching on this forum to get some info on rust repair, but haven't been to successful. I have some pretty bad rust spots on the body because of paint chips and plan on fixing them this summer. Then if money allows let maaco do a cheap, down 'n dirty paint job. I need some help on what methods and materials are used in fixing different types of rust. I'll start off with some pictures:
First, the rust bubble. This is located on the bottom edge on the passenger side rocker panel. I'm guessing sand it down, grind what is left, but not sure what to do from there. I'm probably also going to need to get behind it and make sure there is not rust there to.
Here is the first of two large paint chips. You can see that more paint has chipped off recently and if I wanted to I could go out there and just start pulling more chips off, so I'm not sure how do address this. Oh, and this is located on the passenger side rear quarter panel, just above the fender. These two pics should also be flipped, not sure why they aren't.
And finally, the worst one of them all. This is due to the previous owner rolling the jeep. I'm not sure if they did body work on it and it was just really crappy work, or it was just left alone. I also know this is a bad spot because it is just under the passenger side taillight where one of the body mounts is. Like to the previous paint ship, it is pretty deep and I'm not sure how far it keeps going under the paint.
I'm guessing this is mostly caused be the previous owner laying it on its side because it all seems to be on the passenger side. Also what should I do to seal it? Since I don't want to worry about paint, would a good primer/sealer be good?
Anyone's help is greatly appreciated.
freeskier93 is offline
post #2 of 11 Old 05-27-2010, 01:08 PM
mattyrayb
damn did they skim coat the jeep with bondo or something? or is the camera just really REALLY close up
mattyrayb is offline
post #3 of 11 Old 05-27-2010, 01:10 PM
SFC_Medina
Mighty Glass works well. Check out my post at the following link: Summary of a YJ Face Lift - Jeep Wrangler Forum
SFC_Medina is offline
post #4 of 11 Old 05-27-2010, 02:13 PM Thread Starter
freeskier93
The camera isn't THAT close, I can go take pics not so close though. But I am taking pics with a 14.7 megapixel camera at 4000x3000 pixels, so it makes it look a bit bigger. I would also guess the chips are 1/16 of an inch to 2/16 of an inch deep.
post #5 of 11 Old 05-27-2010, 02:38 PM
tjkj2002
2002 KJ Liberty
That's alot of body filler(bondo)
Your going to have to grind all that body filler off,grind away all the rust and hope the metal is still thick enough.Redo all the body work and repaint.
Or cut out bad panels and replace with new panels and repaint.
Improper surface prep was the cause of your issues.Your Jeep was wrecked and repaired very badly.
tjkj2002 is offline
post #6 of 11 Old 05-27-2010, 03:14 PM Thread Starter
freeskier93
It was known when my dad bought it that the first owner laid it on its side, but I guess we never knew just how bad it was. I saw on quadratec they have new body panels in the area of 40-50 dollars. Maybe It would be easier just to replace the panels? We do have a welder, but replacing body panels seems a bit hard.
Or maybe I should just take it to Colorado Auto Body and let them rape me of my money.
post #7 of 11 Old 05-27-2010, 04:19 PM
gtome
WOW
You are gunna have to get that off of there. I think I see a full strip in your future. If they are willing to do that...... who knows what other crazy stuff they have done. I hope the metal can be saved!! Looks pretty crusty though.
Where is that on the Jeep? The pics are pretty close, and I dont have a Jeep yet, so im not sure where the damage is located.
gtome is offline
post #8 of 11 Old 12-21-2014, 06:02 AM
Tmoore95
hey i just picked up a 91 yj and it has a good many rust spots and the driver's side floor pannel is rusted through any ideas? should I just cut out the section with hole and MIG some new plates on it?
Tmoore95 is offline
post #9 of 11 Old 12-24-2014, 12:43 PM
OrangeCJ-5
1978 CJ5
Floor panels are available. I ordered several pieces from Classic Enterprises (classicent.com) and was happy with the quality. It depends on how correct you want it to be and how much fabrication work you want to do.
OrangeCJ-5 is offline
post #10 of 11 Old 04-30-2015, 10:49 AM
_Kyle_
_Kyle_'s Avatar
Has anyone had any luck using sand blasting/a DA sander to remove at much rust as possible and using a paintable rust remover primer or something along those lines? None of my rust is in places you will really see, so I'm not overly concerned with a show room quality repair - but I don't have the means to cut out the old metal and weld in new pieces.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #11 of 11 Old 05-01-2015, 12:36 PM
IRQVET
1967 CJ5
I deal with rust doing the following:
Major Rust- Cut out sheet metal and weld in replacement patches.
Moderate Rust- Wire wheel/ rust eater, naval jelly, shoot it with rust encapsulator, and then paint.
Minor Rust- Wire wheel/ rust eater, prime and then paint.
Everyone has their own method, but thats what I do for better or for worse.
67 Dauntless CJ5- Seņor Money Pit
1998 Chevy Tahoe, 2D, 4WD, 2 in. lift, 33' Duratracs
IRQVET is offline
need something to stop rust? Deadhorse Paint and Body 9 09-04-2010 08:54 AM
Rust and Body Removal Rynoman27 Paint and Body 2 02-27-2010 04:44 PM
Why so much Rust? turkish6 Paint and Body 14 11-13-2009 12:15 AM
Proper way to repair a rust spot w/ paint and clear... ISUzj Paint and Body 9 11-11-2009 08:03 AM
