body issue? - JeepForum.com
post #1 of 4 Old 05-01-2013, 04:50 PM Thread Starter
TonyCOBHC666
body issue?
if anyone can help me out that be great. the 1st pic is my left side (driver) rear near the tail light where that part meets the body and the 2nd picture is the same area on the right side (passenger). Clearly the driver side is ****ed up, does that need to be welded back together to look as good as the passenger side? any help would be great, long time jeep lover and this is my 1st jeep so help ASAP. thanks
TonyCOBHC666 is offline
post #2 of 4 Old 05-01-2013, 04:59 PM
rjbruzan
Must have been repaired in a body shop at some time. If its loose it will need to be welded up. Next sand blasted in the joint to remove the rust. Primed with epoxy primer,the joint filled with seam sealer then repainted. All because of a poor repair.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 4 Old 05-02-2013, 09:20 AM Thread Starter
TonyCOBHC666
thanks for the help, where specifically should i weld up?
post #4 of 4 Old 05-02-2013, 11:45 AM
rjbruzan
The seam would be spot or rosett welded from in the wheelwell. That is if its loose. First pull the inner wheel liner and inspect.
rjbruzan is offline
