I have recently received my new bumper from JCR and here in the next week or so I will be rattle canning it. I would prefer to have some way to hang it in the back yard to I can paint it as effeciently as possible. I know there have to be some people in here that have had some guinness ideas on ways to do this so please let me know... Pictures are always appreciated....
i used 2 metal saw horses. for my Jcr stuff/ just prep it and waited to dry to turn it over. I just used rattle cans. Rocks eat at paint so going with anything exepensive here was waist of $/time. touch up is easy. Used rustoleum etching primer and then black satin. .
Coat hangers or bailing wire if you have bolt holes. If you can't hang it high enough saw horses or something similar is good. I use old cat litter containers just recycle them when I'm done with the project.
This is the solution that I came up with for Those that are interested...
Using these screws and about 30ft of Paracord I set up a "Clothes Line" in the back yard.
Then In order to keep this from turning into a fence painting project I lined the fence with some simple painters protective sheeting.
Then using Zip Ties through the D ring tabs....:shhh:.... I hung up the bumper. Not the most idea because of the surface area that the Zip-Ties cover but it worked decently. And then Prodeeced to laydown the 3 coats of Rustoleum Self Etching Primer.
Start of the first coat of the final color.... Rustoleum Satin Black Protective Enamel.
Here is the final product.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
