Best way to get a satin or flat color? - JeepForum.com
post #1 of 14 Old 10-14-2009, 06:31 AM Thread Starter
alex211
1995 XJ Cherokee
I want to paint my jeep a desert sand color when I get the tub all fixed up and I was wondering what the best way to do this was. Should I use single stage or two stage paint and where is a good place to get it. I have been around painting before and know how to block sand primer after the metal and filler work has been done. I just have never tried to get a flat paint job. thanks
95 xj bone stock for now
alex211 is offline
post #2 of 14 Old 10-14-2009, 03:47 PM
Roye77
2011 JK Wrangler
You can actually by flatners for clear coats (an additive). Check with your local Napa, Carquest or such or a local body shop might point you in the right direction if they're nice.
"All men are created equal, then a few become firemen." ~Author Unknown
"Volunteer firemen do it for free!" ~Author Unknown
Roye77 is offline
post #3 of 14 Old 10-15-2009, 12:39 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
For this effect, you can also have a tintable primer made to the color needed and leave the primer as the finish coat.
I've also seen some crazies who rubbed out a glossy finish with fine steel wool or wet sanded to remove all traces of gloss.
RE previous post:
Spraying a flat or satin clear over your color is more durable than diluting the paint with liquid flattening additive. Also uses less coats since flattener kills hiding strength
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #4 of 14 Old 10-15-2009, 02:21 PM Thread Starter
alex211
1995 XJ Cherokee
I figured I could use a base coat with a satin clear. When ever the time comes for paint I'll see what the auto body shop says.
alex211 is offline
post #5 of 14 Old 10-15-2009, 03:40 PM
Camarofreak86
Ay buddy how's it going?
I am a painter for the government. fighter jets, tanks, bombs...all that "good ****"
The Best way to get a flat color to be honest with you, is either A: buy a flat paint or B: use a tinted Primer and just use it as your base coat.
It is NOT detrimental to use a pigmented coat on top of primer, that is just for looks. Primer can be used as a stand alone product, and will seal the vehicle just as well....
Camarofreak86 is offline
post #6 of 14 Old 10-15-2009, 03:58 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
He is correct. If you do use tinted primer, use urethane primer and not epoxy primer or polyester. Epoxy will get chalky, polyester is junk.
Connect with us on:
post #7 of 14 Old 10-20-2009, 01:17 PM
Coptrdoc
1982 CJ7
You will have to post pics of your paint job. I am doing the same thing to my CJ. Orange is one of my favorite colors, but want to do something I don't see everyday.
Want to go to a flat desert tan, I been looking at Hotrod flatz Thinking of doing frame and all. Only problem is my Aluminum wheels, but they do have a satin finish. Good luck
Orange 82 CJ-7, Holley, I6, T5, Dana 300, Amc 20, Dana 30,
1.5 Bodylift, AGR Superbox 2, HB Bumpers & Rockers
33" FS Destination MT's
Work In Progress
Coptrdoc is offline
post #8 of 14 Old 10-20-2009, 05:03 PM
95_YJ-pos
or use CARC paint
95_YJ-pos is offline
post #9 of 14 Old 10-29-2009, 05:01 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
RE previous post:
I have a 95YJ Sahara that has been partially repainted. The clear coat is peeling on the repainted section, (hood and front fenders) and there are other issues with the rest of the paint job such as scratches etc but not rust or rot that is visible. Haven't started poking around it yet.
I want to paint it the same factory color it was: Light Pearlstone
Lt. Pearlstone Pearl Coat. BUT I want it to have as flat a finish as possible and have protection from staining.
So, if I want to get the best flat finish looking paint and want it to be relatively stain resistant then a base coat covered with a satin or flat clear coat is the best way to go, correct?
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #10 of 14 Old 10-29-2009, 05:28 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Yes... Flat or satin clear will hands down offer the best stain resistance. Talk to the body shop or auto paint dealer about using this over a basecoat in the pearl color you want.
Look at PPG or Dupont clears for this as they are likely better than off brands but also more costly.
MagnetMan
Connect with us on:
post #11 of 14 Old 10-29-2009, 06:05 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
MagnetMan
Thanks for the information!
post #12 of 14 Old 10-29-2009, 06:12 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
One more thing... The flatter you go the less stain and mar resistance you will have
Connect with us on:
post #13 of 14 Old 11-21-2010, 12:25 PM
HawkeyeXJ
If you are looking for flat clear and improved resistnace to polish back and easy maring such as typical flat colors and clears then check out the folks at Performance Coatings Specialites Performance Coatings Specialties - Raising the Bar
I know a boat manufactuer that they helped out to create an improved flat coating for their guided duck boats that see daily use. They are very impressed and feel they have one of the best low gloss antislip coatings in their market.
HawkeyeXJ is offline
post #14 of 14 Old 11-22-2010, 06:29 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
I used 16 cans of Aervo 977 Flat Sand to do mine.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
tell me your opinions on color choice Matt_G Paint and Body 5 01-28-2010 03:06 PM
Satin, Semi-Gloss, Hammered Black or Hammered Brown for Tube Fenders? MountainMan864 Paint and Body 3 01-14-2010 08:44 AM
New Paint color poll 97Heep Paint and Body 6 01-11-2010 10:03 AM
What Color Kielykid64 Paint and Body 0 12-08-2009 01:05 PM
Need Paint (Color) help A.S.A.P. Krayzie949 Paint and Body 1 10-09-2009 04:34 PM
