Best way to fix crumpled body? - JeepForum.com
post #1 of 11 Old 11-05-2013, 05:05 PM Thread Starter
ChanceStock
Here are a shots of my damage. The jeep was in a front end crash and the rocker panels were crunched a little. Sorry if it's hard to tell in the pictures. But what is the best way to fix this as best as possible at home?
ChanceStock is offline
post #2 of 11 Old 11-05-2013, 05:35 PM
222Doc
222Doc's Avatar
frame still straight? that buckling is a sign. body shift off the mounts?
222Doc is online now
post #3 of 11 Old 11-05-2013, 05:59 PM Thread Starter
ChanceStock
frame is only bent on the very end where the bumper mounts. Doesn't effect driving.
post #4 of 11 Old 11-08-2013, 10:52 PM
222Doc
222Doc's Avatar
How did you check that? Just eyeball it?
post #5 of 11 Old 11-09-2013, 08:42 AM Thread Starter
ChanceStock
we had it checked at a shop
post #6 of 11 Old 11-09-2013, 09:58 AM
ToledoDave
Ouch! How does the door fit? I would get a stud gun and start studding and pulling the dents outs. If door still fits with 3-4 mm gaps all around then ya got lucky.
ToledoDave is offline
post #7 of 11 Old 11-09-2013, 02:34 PM
ToledoDave
Just food for thought.... our 700 miles 3 week old JK T-boned a drunk kid turning left in front of us. Front axle bent and frame diamonded and rt side frame horn raised 1.5 inches and it couldnt be straightened or pulled. As far as body dmg. Only rt fender and bumper replaced. You occured alot! More dmg in the body which makes me want to think theres more frame dmg then ya see. Were at 13k dmg on a 700 mile vehicle. Seeing your body dmg tells me your in a pickle. I would bet theres more dmg.
post #8 of 11 Old 11-14-2013, 03:32 AM
SunDevilJeeper
A propane torch and a set of different hammers can fix it. That's how I fixed a few dents on my Jeep.
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #9 of 11 Old 11-14-2013, 12:26 PM
goldhammer
1988 XJ Cherokee
This from a bodyman with over 35 years in the trade.....that damage says to me that the frame is down at the cowl(firewall) to cause buckles there, and I would say it's down by at least 1/2 inch, maybe a little more. You need to get it checked with gauges, etc and see where the datum is at and that it is straight all the way through.
When the frame is straight then you can finish working out the rest of it by hammer and dolly since most of it is single wall and has access from both sides. Most should come out with the frame pull and they can work it then as well.
goldhammer is offline
post #10 of 11 Old 11-22-2013, 08:28 AM
ToledoDave
You wont be able to dolly anything on that rocker. There is an inner panel inside the rocker. Your only chance is to pull the dents with an Eagle dent puller or a stud gun type. You wont get behind that panel. As far as frame damage. Frame isnt connected to body but hy only body bolts. Which all the body bolt mounts are floating nuts inside the cage. Problem u have is if the outter skin is dmged and the interior is then the panel on the inside is too. The rockers are the strongest area on that body. I agree theres more frame dmg then meets the eye but a rocker repair like that is not going to be easy. If you only knew how many of those I have repaired. Good luck.
post #11 of 11 Old 11-22-2013, 02:37 PM
duramax-rob
Retired bodyman. seems the frame is still not correct. if body to frame bolts look like the arent offcenter or in a pinch, then the frame and body are still bent. pull the frame and body at same time and work the kinks in body out while straightning.
duramax-rob is offline
