Bedliner vs. new bedtred material - JeepForum.com
post #1 of 5 Old 02-28-2013, 05:32 PM Thread Starter
kelzac23
I was thinking about coating the entire floor pan with bed liner. I found the bedtred and have been going back and forth on what I want to do. Or even both! Any have any reviews about the bedtred. And does the bed liner cut any noise out? All you hear is exhaust and road noise which doesn't bother me but the gf doesn't like it.
kelzac23 is offline
post #2 of 5 Old 03-01-2013, 01:05 PM
Jims-87YJ
1987 YJ Wrangler
Take a look in the Vendor display section for Monstaliner! you can also check out my build thread. It will not cut out road noise, I did put in the heavy duty floor liners in the front, easier to take out and clean when they get full of crap, that helped deaden the sound a small amount. Overall very happy and would do it again.
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #3 of 5 Old 03-02-2013, 07:11 PM
Gates72ss
I ended up using a smooth bedliner and it looks great , has not cut down on any noise but sure does make clean up a snap....
Gates72ss is offline
post #4 of 5 Old 03-02-2013, 11:19 PM Thread Starter
kelzac23
What brand? I've seen that rustoleum is pretty smooth
kelzac23 is offline
post #5 of 5 Old 03-02-2013, 11:28 PM
StuddMuffinz
No offense, but if you're going to do a liner, spend a little bit more and get a quality liner: UPOL Raptor if you have the capabilities to spray, Monstaliner if you must roll. Either of the two can be applied rough, smooth, and anywhere in between.
It's much easier to spend extra and do it right than it is to cheap out and later try to rip that out and start over.
Y ~ N ~ W ~ A
StuddMuffinz is offline
