Bedliner rewiews? - JeepForum.com
post #1 of 10 Old 01-27-2011, 10:53 AM Thread Starter
JeepsterFloyd
Bedliner rewiews?
Starting to prepare my 1989 YJ, so that I can coat the floorboard with spray or roll-on bedliner. Anyone have good or bad experiences with certain brands of the stuff? I hate to do this a second time!
JeepsterFloyd is offline
post #2 of 10 Old 01-27-2011, 02:41 PM
CopperCJ7
I used Herculiner on my CJ, but you need to buy their UV coating if it gets prolonged exposure to the Sun otherwise it will fade to gray. It took 1-1/4 gallons of the Herculiner to do 2 coats on my tub, bottom portion of the roll bar, 4 wheel wells and my gas talk skid plate.
I hear nothing but great things from people who have used Monstaliner, Raptor and Durabak. The advantage to using Durabak is that they make 16 different colors and it's formulated for interiors and exteriors. I'm happy with my Herculiner, but if I did it over again, I'd probably use Durabak or Raptor.
The only advice I can give you is take your time with the prep. Remove everything - even the tub plugs and the roll bar if you can. Use a strong cleaner - like "Marine Clean" and remove ANY particles and dust before you roll the liner in. Spend the extra money on good masking tape and really mask everything off. Wear a throw-away coveralls and MAKE SURE to wear gloves, a respirator AND lay down a large tarp. Once the stuff gets on concrete, or your clothes - it isn't coming off. I used gasoline to remove it from my skin. Stick wadded-up masking tape pieces in the tub holes and any exposed threaded holes for the roll bar and seat, etc.
Don't pay for a company to spray it in. It's so much cheaper to do it yourself.
Guns don't kill people... Bad trail spotters do.
What CJ owner doesn't want to hack up his harness for the next owner to have fun with?
Originally Posted by Broseph View Post
The thread will derail quicker than a walrus on a Crisco-soaked Slip 'n' Slide.
CopperCJ7 is offline
post #3 of 10 Old 01-29-2011, 08:56 AM
saginawmike
I'm thinking of spraying black bedliner on my Rock Hard off road bumpers and was wondering if they fade or turn grey from UV light. Are any brands more resistant to fading? I'm sure they all look nice when new. How about some long term reviews?
saginawmike is offline
post #4 of 10 Old 01-29-2011, 10:01 AM
CopperCJ7
Check out Monstaliner and Durabak. Both have UV resistance. Durabak is actually made for exteriors as well and comes in 16 colors.
post #5 of 10 Old 02-01-2011, 04:16 PM
Graffxman
1976 CJ7
I used Duraliner in spray cans from Walmart (did interior and hardtop). Went on easy and I haven't had a problem with it (yet). Make sure you mask off well, overspray goes everywhere!
Graffxman
'76 CJ7--304 V8
Graffxman is offline
post #6 of 10 Old 02-01-2011, 06:29 PM
CopperCJ7
That top came out nice
post #7 of 10 Old 02-01-2011, 09:17 PM
jsc7002
1966 CJ5
X2 Herculiner, I used it on my KJ and it did fade but I liked it, it was more of a flat black then. Held up great! I scratched it with my keys and it didnt do anything. Easy to apply takes a while to do all the correct prep work but its well worth it. I will be using it on my XJ.
jsc7002 is offline
post #8 of 10 Old 02-02-2011, 07:16 AM
Graffxman
1976 CJ7
I was pleased with the way the top came out. The windows had that old, faded purple, wrinkled up tint on them. Cleaned them all off, painted inside and out with the Duraliner. Did that 4 months ago, still not a scratch, flake, or peel anywhere.
Graffxman
'76 CJ7--304 V8
post #9 of 10 Old 02-02-2011, 09:42 AM
CopperCJ7
Graffxman, now all you need to address is the fact that your tires are too big for that lift (or lack thereof).
post #10 of 10 Old 02-02-2011, 09:55 AM
Graffxman
1976 CJ7
Yep, working on that. Budget has me waiting a little, but decided on 4" springs.
Looked at SOA, body lift, add-a-leaf, etc. and decided to wait and do it right.
It does rub a little on big bumps........
Graffxman
'76 CJ7--304 V8
Bedliner questions Jbecker Paint and Body 4 02-25-2011 06:30 PM
Bedliner Sanding... D3f4ult Paint and Body 6 11-20-2010 04:18 AM
rolling bedliner on whole WJ? kingplay334 Paint and Body 12 10-20-2010 09:10 PM
Has anyone used this diy bedliner kit mknight759 Paint and Body 1 08-02-2010 12:01 AM
Spraying Bedliner UzbekJeep Paint and Body 4 07-05-2010 09:45 PM
