Bedliner Questions - JeepForum.com
post #1 of 7 Old 01-01-2010, 10:30 PM Thread Starter
Thexonexkid
Thexonexkid's Avatar
1986 XJ Cherokee
Bedliner Questions
I realize this thread exists:
http://www.jeepforum.com/forum/f260/...ide-tj-872715/
This thread was going the direction I was wanting (what product to use) but then switched up to how to apply it (which I am pretty sure I have down but if you want to drop your two cents in thats fine).
So yeah major question is what products you think work best roll or spray what brand? Do I have to use a compressor?
Also iv got bed liner already on my tube fenders and about a square piece an inch by an inch came off (not sure how). I don't know the brand (didn't put it on) is it still ok if I don't get the brand that was originally used and just roll over that spot?
Like I said if you got any extra tips or tricks for applying bed liner on the inside of a TJ let me know. This project is a little ways off but thought I'd just get input now.
84 CJ7 Rebuild:
Thexonexkid is offline
post #2 of 7 Old 01-01-2010, 11:44 PM
WILLTAKE
I have Herc'ed the inside of two YJ's with a roller and they came out pretty good. Main thing I would recommend is to follow the prep directions very closely and not rush it at all. I also saw this write up on Monstaliner and thought it was a very good article and good looking product
http://www.jeepforum.com/forum/f9/mo...ite-up-901675/
Key thing to watch is your seatbelts- make sure to pull out a little extra slack in the belt and tape or clip it off before removing the seat belt from the Jeep, otherwise it may (will) retract and getting the belt back out will be a major PIA or impossible
WILLTAKE is offline
post #3 of 7 Old 01-02-2010, 08:30 AM
Whobeme
2010 JK Wrangler
Here is the route I went with. • View topic - Al's Liner bed liner write up
What area of Iowa are you in? I'm in Camanche, just north of the Quad Cities.
Whobeme is offline
post #4 of 7 Old 01-02-2010, 05:44 PM Thread Starter
Thexonexkid
1986 XJ Cherokee
cedar rapids/iowa city
84 CJ7 Rebuild:
post #5 of 7 Old 02-25-2011, 06:35 PM
sa3040krag
U-pol Makes a spray-able bed liner called Raptor. It comes black, gray, white, and tint-able. It's $120 a kit and the gun (shultz gun) is about $30. to prep just DA it with 80 grit, clean real good with a wax and grease remover (prep sol), mask and spray. Keep the gun 3-4 feet back and spray like you would paint. The farther away you get the rougher the texture. It sprays easily and hides 80 grit scratches no problem. I sprayed the roof of my cherokee with the tint-able a year ago and it still looks like day 1. I would give it a few days to dry before standing all over it.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
sa3040krag is offline
post #6 of 7 Old 02-27-2011, 05:42 PM
4link
how long does the hurculiner take to dry? actually the whole process really, i was thinking about doin my tub tomorrow but i work the day after and dont want to mess it up
- Your Fellow Jeep Creep
4link is offline
post #7 of 7 Old 03-06-2011, 01:16 PM
bhillsburg
Sweet!
bhillsburg is offline
Lined my tub with Duplicolor bedliner sam24th Paint and Body 16 08-22-2011 05:16 PM
Which roll-on bedliner??? atomicjoe23 Paint and Body 7 02-16-2010 07:31 AM
Zolatone paint questions frank c Paint and Body 0 01-19-2010 05:13 AM
yet another bedliner thread, durabak siuXJ Paint and Body 4 01-02-2010 08:06 AM
Getting ready to paint...a few questions notforsale Paint and Body 10 11-02-2009 08:37 AM
