Another paint option... (Trinity paint) - Page 3 - JeepForum.com
post #31 of 43 Old 12-22-2011, 09:17 AM
portcityXJ
1995 XJ Cherokee
okay so i got my trinity acrylic urethane paint kit. the gallon of color says to mix 4:1 reducer. do i need an activator? i was sent a pint of hardener but no activator. The webite says 8:2:1. did i get the wrong stuff?
from the site:
Ratio is 8 parts paint, 2 parts Urethane Reducer, 1 Part Urethane activator.
also i have a lacquer primer. i think i thin it 1:1 with lacquer thinner. does that sound right?
I approve this message.
Originally Posted by EricRollerSkate View Post
Do they come in any other varieties besides crap?
portcityXJ is offline
post #32 of 43 Old 12-23-2011, 06:33 AM
AndreLeMoine
Paint
Maybe the hardener that they sent you is the activator? A question of terminology maybe? I ended up purchasing Kirker " Winter White " for my CJ7. I bought the start to finish kit that is sold on Smartshopper.com. Too cold to paint right now so just lots of sanding and prep. I decided on the white because of the summers we have here. Looking forward to laying down some paint but willing to be patient. Andre.
AndreLeMoine is offline
post #33 of 43 Old 12-23-2011, 07:31 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Hardener is going to be the activator.
Sent from my DROID3 using JeepForum
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #34 of 43 Old 12-25-2011, 03:54 PM
portcityXJ
1995 XJ Cherokee
Thanks guys. If I need to thin the paint, what do I use? its acrylic urethane.
post #35 of 43 Old 12-27-2011, 06:59 AM
AndreLeMoine
There should be "reducer" available for your paint and it may be temperature dependent, ie- above 80 degrees, below 80 degrees, 60-70 degrees etc,. Contact your paint supplier. Andre.
post #36 of 43 Old 12-29-2011, 05:38 PM
portcityXJ
1995 XJ Cherokee
Got the jeep primed. Two good coats, no runs. Do I need to sand the primer before spraying the topcoat? or just wipe it down with the tack cloth?
post #37 of 43 Old 12-29-2011, 06:46 PM
paulmv17
If you don't apply the topcoat within the primers topcoat timeframe, the info will be on the can or in the paperwork you got with it, you will have to sand the primer. If your certain that you don't have any runs or imperfections and can apply with in the time frame then no sanding needed. If it were me I would let the primer cure and then sand to your liking then topcoat. Just my opinion though
paulmv17 is offline
post #38 of 43 Old 12-29-2011, 09:38 PM
kenlena46
Nice
kenlena46 is offline
post #39 of 43 Old 12-30-2011, 03:08 PM
portcityXJ
1995 XJ Cherokee
Well I asked a few friends what they would do. I was told to wet sand the primer with 600 grit and wipe it down. I'm spraying the topcoat tomorrow so I'll tack-cloth it in the morning beforehand. I got a couple propane heaters for drying the topcoats.
After I finish the topcoats, what then? How long does it need to sit before I drive it out into the weather?
post #40 of 43 Old 05-17-2013, 10:40 AM
CJ7ROB
Originally Posted by SCJeepr View Post
Well i could not be happier with outcome of the Trinity paint that i got. I sprayed the hood, tailgate, dash, front fenders and windshield frame last night with great results and not a run one. My first time ever touching a spray gun too. I think that says a lot of the paints ease of use. I did think that the Blue Sapphire Metallic that i got would be more blue but it is sooooo dark that it has a purple-ish look to it. THE METALLIC IN THIS PAINT IS INCREDIBLE!!!!!!!!!!. Enjoy the pics.
SCjeepr, that came out awesome. I have the same paint but metallic blue color. Howd you get it to go on so shiny?
CJ7ROB is offline
post #41 of 43 Old 05-20-2013, 06:17 AM
SCJeepr
1982 CJ8
All I did was follow the instructions and this is how it came out. I have had to buff out the hood a couple of times. This paint seems to oxidize relatively easy in direct sun light on and on. I will be using it on my next project as well.
Christian Jeepers
"Crawling our way to Heaven one rock at a time."
SCJeepr is offline
post #42 of 43 Old 09-06-2013, 03:25 PM
462FSJ
1973 J-Series Truck
Originally Posted by Norcalcj5 View Post
Here's another pic with the cage in.
Attachment 284130
Attachment 284132
462FSJ is offline
post #43 of 43 Old 09-06-2013, 10:38 PM
kodiakwj
2003 WJ
I've been looking for something like this for my WJ. I was going to plasti dip the whole thing but this is much cheaper. Plus my buddy has a spray booth and will shoot it cheap. I might use the fathem green. I think it would look cool on a WJ especially since mine has dark tinted windows and taillights.
kodiakwj is offline
New paint job over spray paint? HRDCOR4PLY Paint and Body 20 02-12-2011 05:55 PM
need opinions, to paint or not to paint. BARKDOG67 Paint and Body 18 01-23-2011 10:10 AM
how do i get this off my paint emayer32 Paint and Body 16 08-28-2010 10:09 PM
Body Cladding Paint - Is it possible to have a quality paint job on them? TonyMontana Paint and Body 0 05-02-2010 12:25 AM
If you're broke like me and spray paint is a first option.. rosato19 Paint and Body 14 11-17-2009 05:48 PM
