another herculiner - JeepForum.com
post #1 of 4 Old 10-25-2009, 08:57 PM Thread Starter
88YJoe
another herculiner
i just bought flap wheels for the grinder the po did a crapy jjob on the floor and its peeling can i sand to bare metal and apply herc??? or bad idea?
88YJoe is offline
post #2 of 4 Old 10-27-2009, 08:13 PM Thread Starter
88YJoe
bump anyone?
88YJoe is offline
post #3 of 4 Old 10-27-2009, 08:18 PM
gtistiffler
I think it would probably be best to apply some self etching primer to the bare metal then apply the herculiner.
2006 TJ "X" 4.0, 2" BB, JK 17" Wheels,etc
gtistiffler is offline
post #4 of 4 Old 10-27-2009, 11:09 PM
Low98Dime
What did the po put on the floor? If its bedliner or undercoating you might want to wear a good respirator, that stuff is nasty if u inhale it. If its ruff stuff you might want to get a braided cup-style wire wheel for your grinder and hit it with that to get off some of the texture first and then switch to the flap disk, unless u want to clog up ur flap disk really quick. Then just wipe down the entire floor with some acetone or some type of prep cleaner, I would spray on some self etching primer where it is down to bare metal and then lay down the liner. Follow the directions on the can.
Low98Dime is offline
Herculiner application inside a TJ RedJeep2002 Paint and Body 19 10-18-2010 08:19 PM
Removing Herculiner GroundAssault Paint and Body 15 05-24-2010 10:37 PM
Herculiner Exterior teufelhundren Paint and Body 1 02-02-2010 09:06 PM
Herculiner Black Paint Jeep YJ Hard Top Urb4nTr0ll Paint and Body 6 01-22-2010 01:29 PM
Where to get Herculiner? PrJeep Paint and Body 10 01-02-2010 12:28 PM
