95 YJ hard top screws are stuck - JeepForum.com
post #1 of 4 Old 04-20-2013, 11:23 PM Thread Starter
Trentl14
The previous owner never took it off. I assume its rust or something so I WD40'd the screws, then took a score driver but to no avail. Then the cordless drill. Stopped it dead. Then the plug in electric drill. Not even a wiggle. Do you guys have an idea for me?
Trentl14 is offline
post #2 of 4 Old 05-09-2013, 06:47 PM
tybota
Can you cut the screws with a dremel?
tybota is offline
post #3 of 4 Old 06-10-2013, 08:09 AM
Rio42
Had the same problem, PO never took it off. In the end I had to use disk grinder (mine hooks up to an air compressor). It will be faster than a dremel, just be careful. Also check to see if the "rectangle" nuts aren't just twisting around, that was a big problem for me.
Rio42 is offline
post #4 of 4 Old 06-16-2013, 08:05 PM
Bigmeats
Have you tried a hand impact driver? This worked wonders on the the last jeep I took apart. Good luck!
Bigmeats is offline
