-   Paint and Body (http://www.jeepforum.com/forum/f260/)
-   -   95 YJ hard top screws are stuck (http://www.jeepforum.com/forum/f260/95-yj-hard-top-screws-stuck-1512236/)
Trentl14 04-20-2013 11:23 PM
The previous owner never took it off. I assume its rust or something so I WD40'd the screws, then took a score driver but to no avail. Then the cordless drill. Stopped it dead. Then the plug in electric drill. Not even a wiggle. Do you guys have an idea for me?
tybota 05-09-2013 06:47 PM
Can you cut the screws with a dremel?
Rio42 06-10-2013 08:09 AM
Had the same problem, PO never took it off. In the end I had to use disk grinder (mine hooks up to an air compressor). It will be faster than a dremel, just be careful. Also check to see if the "rectangle" nuts aren't just twisting around, that was a big problem for me.
Bigmeats 06-16-2013 08:05 PM
1 Attachment(s)
Have you tried a hand impact driver? This worked wonders on the the last jeep I took apart. Good luck!
The time now is 08:31 PM.
